2011 Honda PCX 125 - Stripped Oil Filter...
itsmeek0
Post by itsmeek0 »
Hi,
I tried to take out my oil filter the other day to clean it and the damn thing stripped a bit... Im considering a few things, please advise?
1. The cap seems quite stuck on the bike. Im not sure what to do... Maybe WD40 and I can get it off before it completely strips and replace it?
2. If I cannot get it off, will this be detrimental to the bike?
3. Any advise or tips?
This is what the cap looks like. Its in a terrible spot and the head for the socket to fit on is small.
Thank you.
Re: 2011 Honda PCX 125 - Stripped Oil Filter...
Is it one of these? Hard to tell from your blurry photo.
Cheap on eBay.
The fewer corners or points on your socket or wrench the better.
Generally, nothing of substance is found in the screen after the engine is run-in. Caps are made out of crap metal - and deform easily.
I've put a box wrench on them and tapped the wrench with a mallet to break them loose.
OR, drain the oil with the drain plug and leave this thing alone.
Use an adjustable spanner adjusted tight.
Ideally so it needs to be gently tapped over the damaged head from the side.
Gil
Post by Gil »
I'm with Fish here, the "filter" is mostly for big pieces of metal shavings that are sometimes left inside the engine at the factory. I have never found anything in them, but have seen people in forums find metal pieces on the first time they clean the "filter". I would just let it be, if you have cleaned it before. Now if you want to open it up, you can use an old trick to loosen tighten bolts/nuts. Tap it lightly with a hammer all around to loosen the threads a bit. Then you can put a closed end wrench on it and tap the other end of the wrench with a hammer with light hits to nudge it along.
Leave it alone, it doesn't do anything after the engine is run-in and had its first couple of oil changes.
springer1
Year: 2018
Post by springer1 »
gn2 wrote:Leave it alone, it doesn't do anything after the engine is run-in and had its first couple of oil changes.
+1 ..... as long as it's not busted or cracked or leaking.
Have you unscrewed it partially or screwed it back in cross-thread? If it is where it was originally, leave it. I only check mine every 3 oil changes and I haven't found anything at all since the first oil change, where I found some metal shavings. Use good synthetic oil and you shouldn't have to worry about it.
Inoplanetyanin
Year: 2018
Color: WHITE
Post by Inoplanetyanin »
I removed mine with this bolt extractor set. https://www.lowes.com/pd/IRWIN-BOLT-GRI ... lsrc=aw.ds
I think you need to fix it and install a new one and be careful next time.
It's good to open it up every 4-5 oil change, I think.
Once in a while there are fibers there or hair, or pieces of the gasket.
It's a soft aluminum bolt so to take it out safely, a socket needs to be really good fitting and you need to apply the pressure towards the bolt before turning it. Good luck.
Martin J
Year: 2018
Post by Martin J »
I found a couple of bits of swarf at the first 600 mile oil change, but since then nothing.
Yamaha 900 Diversion '96
Suzuki GS550E '81
Benelli TRK502 '21
Honda PCX 125 '18
Year: 18 300 xmax
1. Get a set of locking vice grips and yank counter clockwise
2. If you mangle it badly, replace it , it’s cheap.
3. Forget about checking it in the future, after the first go around, there’s never much in it. If you are going to check it only use a box wrench on it , something that grabs on all sides.
springer1
Year: 2018
Post by springer1 »
As a very last resort for removing damaged bolts & studs .... get a cheap box wrench or socket that fits (but doesn’t work because it slips). Clean the head & wrench with gasoline to remove all traces of oil. Get JBWeld epoxy and fuse the cheap wrench / socket to the head and let sit for a day to fully fully cure. Wack the wrench with a hammer to unstick the bolt/ plug/ stud. After the bolt etc is out, wack the wrench / epoxy / bolt until They either come apart or break themselves. Usually you can save the wrench / socket.
Inoplanetyanin
Year: 2018
Color: WHITE
springer1 wrote:As a very last resort for removing damaged bolts & studs .... get a cheap box wrench or socket that fits (but doesn’t work because it slips). Clean the head & wrench with gasoline to remove all traces of oil. Get JBWeld epoxy and fuse the cheap wrench / socket to the head and let sit for a day to fully fully cure. Wack the wrench with a hammer to unstick the bolt/ plug/ stud. After the bolt etc is out, wack the wrench / epoxy / bolt until They either come apart or break themselves. Usually you can save the wrench / socket.
Awesome advise.
Only I would use alcohol instead of gasoline (oil) to remove oil :)
