fuel cap wont open
Maintenance, guides, and walkthroughs for your Forza. Please do not post questions about repairing or fixing your bike here.
halluinoid
Year: 2018
Color: blue
fuel cap wont open
Post by halluinoid »
turned the switch to SEAT FUEL (7 o'clock) push the fuel side of the rocker that labelled FUEL/ SEAT
fuel lid remains closed
I cant get it to open :o
2018 Honda Forza 300cc
davenowherejones
Color: Silver
Re: fuel cap wont open
Post by davenowherejones »
It is a safety feature. If you are not smart enough to get the fuel in then you should't be riding!
Just kidding but I had an elderly friend who could not start his car because he had forgotten he had to have his foot on the brake to turn the key.
He was at the beginnings of Alzheimers. Later he did start his car and I had to jump on my scooter to track him down. Sad case.
Try jiggling the key, the bars and the fuel flap door. Gently tap on everything also.
Is the 2018 a mechanical system like the earlier 2014's?
halluinoid
Year: 2018
Color: blue
I assume so, it does appear that way, looks like I'm going nowhere until this is sorted :?
Yorkie150
Year: 2018/19
Color: RED
Post by Yorkie150 »
push the flap down slightly as you press the switch .....the dirt/grime '' gremlins are everywhere in this weather and can make these catches stick a bit
Had the opposite problem with mine, it wouldn't stay shut.
Jammed cardboard in the latch and that did the trick.
+1 on the wiggle and jiggle to open reluctant flaps...
Get on the phone to the dealer pronto
I carry a pocket knife just for that possibility. Sometimes the mechanical switch works but the door sticks. A thin screwdriver will also work. Push the fuel button while gently prying the door up.
If that does not work you may end up taking the plastic off that holds the fuel door and spraying some wd40 in/on the cable.
halluinoid
Year: 2018
Color: blue
bearing in mind I have never seen this door open yet...... while gently prying the door up? from which side ? 8)
davenowherejones
Color: Silver
Do you have the keyless dongle in you pocket and does it have working batteries? Does it have a fuel button?
I did not know it was very new, call your dealer.
Mark65
Color: Blue
Post by Mark65 »
halluinoid wrote:bearing in mind I have never seen this door open yet...... while gently prying the door up? from which side ? 8)
Press the fuel flap button and at the same time press the plastic behind the hinge of the flap, it will open a few times then stop again.
halluinoid
Year: 2018
Color: blue
didn't work
Mel46 wrote:I carry a pocket knife just for that possibility. Sometimes the mechanical switch works but the door sticks. A thin screwdriver will also work. Push the fuel button while gently prying the door up..
:lol: SUCCESS! Mel46 I now carry a pocket knife just for that possibility
straight to petrol station, 10L straight into the tank, it's FULL and the vehicle is at WARP FACTOR 8, thanks to all, back in business :P 8)
davenowherejones
Color: Silver
halluinoid wrote:didn't work
Now take it to your dealer and tell them to FIX it.
