Help: Top Box hardware
ChuckD
Color: Blue
Post by ChuckD »
OK, I'm thick...
If I order this: https://smile.amazon.com/gp/product/B07 ... TMA5&psc=1 (it comes with a "mounting bracket" and hardware)... what other fitting kit do I need for my 2017 PCX150?
Thanks so much!
Chuck
2017 PCX150
Re: Help: Top Box hardware
You need a Givi SR1163 rack or equivalent.
https://www.amazon.com/GIVI-SR1136-Mono ... B00TPEHY1K
There's a panel in the grabrail that comes off revealing four bolt holes that the two parts of the rack fix to.
The flat plate in the kit you're ordering then secures to the SR1136 and the case goes on that.
Its a really easy job.
ChuckD
Color: Blue
Post by ChuckD »
Thanks...
I'm in the US. The Givi SR1163 appears to be (expensive) import-to-US only.
2017 PCX150
ChuckD
Color: Blue
Post by ChuckD »
O!
Great help!
Thanks, gn2!
2017 PCX150
That was quick! ;) :P
And by the way Chuck you're Not! thick. Welcome aboard!
When you get the panel off you'll see four circles that can be cut out so that the rack fits through the holes.
Only snag with that is if you ever want to go back to not having a rack fitted.
So the alternative is just leave the panel off and keep it in a cupboard so that you can easily restore it to normal should you choose to.
Panel off:
https://www.youtube.com/watch?time_cont ... ic2VJy8rgg
Or
https://youtu.be/yds7MarL4i8
ChuckD
Color: Blue
Post by ChuckD »
I owe ya, buddy... thanks!
2017 PCX150
ChuckD
Color: Blue
Post by ChuckD »
Thanks again for the top box/bracket tips!
I got to tool around on this full moon Friday the 13th...
Loving the new (to me) bike, larger windscreen, and top box!
peace
2017 PCX150
ChuckD
Color: Blue
Post by ChuckD »
The view from the rear...
2017 PCX150
