Retrofitting to European Lighting
pcx888
Color: pearl white
Post by pcx888 »
I was wondering did anyone change there 2011 to 2013 pcx. I European flush mount tail signals and got rid of front turn signals. I hate the U.S. bunny style ears.
2011 White PCX
Aftermarket Thai Seat.
Rear NCY 1000 contra spring.
NCY Textured clutch bell.
Re: Retrofitting to European Lighting
Hmmm...my 2013 model looks just like the 2011 model, aside from the gas tank access lid flipping the opposite direction. If you are in the United States you will see that the changes came in the 2015 model.
pcx888
Color: pearl white
Post by pcx888 »
I found the parts needed but too expensive to retrofit. 100.00 for headlamp assembly. Another 60.00 for the black bottom panel below the center console to cover rabbet ears cutout. and 150.00 to replace rear fender and rear turn signal assembly.
2011 White PCX
The turn signal stalks were required by the government because the bike was considered too narrow by a few inches. You will find some motorcycles fitted with them as well.
If you really want to remove them you might be able to locate some panels at Powerbypcx.com
Price is always a factor when you want to modify a bike.
Gil
Post by Gil »
I retrofitted the EU light sockets on my 2013 Honda pcx by buying the EU headlight harness and drilling out the holes for the bulbs on the headlight housing. I had to use some hot glue on the running lights since they would fall out every now and then.
pcx888
Color: pearl white
Post by pcx888 »
Look what I found. European headlamp 130.00
ebay headlamp.jpg (96.6 KiB) Viewed 10871 times
2011 White PCX
pcx888
Color: pearl white
Post by pcx888 »
Just pulled the plug guys I ordered a new headlamp and rear fender for European or Asian assembly. No more rabbit ears on my bilke will post pictures when the build is complete.
2011 White PCX
pcx888
Color: pearl white
Post by pcx888 »
Gil the bottom lights where did you tap to make them light up. I know the top are turn signals. Middle are headlamps. and Bottom are driving lights.
2011 White PCX
That's what the bottom ones are? Hmm...considering that the headlights come on automatically when the bike is started, why do we need those??
Never mind. I wired mine into the headlights anyway. It just seemed logical.
pcx888
Color: pearl white
Post by pcx888 »
Mel46 wrote:That's what the bottom ones are? Hmm...considering that the headlights come on automatically when the bike is started, why do we need those??
I did the same thing wired to low beam lights,
2011 White PCX
pcx888
Color: pearl white
Post by pcx888 »
heres my pic of new headlight installed.
2011 White PCX
Yorkie150
Year: 2018/19
Color: RED
Post by Yorkie150 »
what's the reason that US model PCX have bunny ear indicators ( turn signals ) ?
pcx888
Color: pearl white
Post by pcx888 »
Yorkie150 wrote:what's the reason that US model PCX have bunny ear indicators ( turn signals ) ?
2011,2012,2013 model had to have bunny ear indicators. Due to bike being too narrow. By a couple of inches. So the rest of the world bikes didn't have them. Stupid regulations. and the start and stop switch.
2011 White PCX
pcx888
Color: pearl white
Post by pcx888 »
Heres pic of the completed project.
TAILLIGHT COMPLETE_00001.jpg (221.83 KiB) Viewed 10600 times
2011 White PCX
Looks great
pcx888
Color: pearl white
Post by pcx888 »
you you wrote:Looks great
Thank you.
2011 White PCX
Gil
Post by Gil »
pcx888 wrote:Gil the bottom lights where did you tap to make them light up. I know the top are turn signals. Middle are headlamps. and Bottom are driving lights.
Late reply, but the second picture is of the driving lights. I just made the hole in the middle of the circle depression in the plastic. I did have to use hot glue otherwise the lights will fall out.
I just wanted everyone on this thread to know that on my 2013, which has LED lights everywhere except in the main headlights, when the battery is low the headlights flicker as you idle, while the LED lights are steady. So, if you start to notice the flickering a lot at lights, chances are good that your battery is having a problem keeping up with the demand. Put the battery on a charger, but keep an eye on it for the inevitable slow starting before the battery gives up on you.
Neither of my off-brand batteries lasted much more than a year before they started giving me the indication that they were not up to the task any more.
Gil
Post by Gil »
Mel46 wrote:when the battery is low the headlights flicker as you idle
I had the same issue when I had the high draw LED headlights on my 2013 PCX. Since I could never get a good light pattern out of them, along with the flickering, I went back to halogen light bulbs.
Gil
Post by Gil »
Halogen light bulbs for the headlights, the rest are still LED.
