Seat recovering ‘how to’ guide
aphid
Color: Pearl Siena Red
Re: Seat recovering ‘how to’ guide
Post by aphid »
jburner wrote:I think if I would do it again, I would have started from the back and work my way forward around the nose portion of the seat.
Although I haven’t tried yet, with the rounded snout to contend with, I think your approach was right. Staple snugly around the nose, pull firmly to the back, then pull the sides. Maybe 4 way stretch vinyl will work out easier.
NADman
Post by NADman »
We used a level on the seat at riding height and put 1/2-3/4" more foam on the 'snout'.
Never slide forward again coming to a stop. Tried to stretch the new fabric but wound up having
a pro do it.
aphid
Post by aphid »
I decided to have a go at a very minimalist approach to 2010-2013 PCX de-humping.
All it needs is pieces of cloth, foam, whatever small scraps you have to hand. These bits are fed through the two holes in the seat cover to pack the space around the two humps.
aphid
Post by aphid »
First, fill the ‘valley’ between the plastic humps (shown from underneath) with pieces of fabric and pack down firmly.
Then fill the spaces as evenly as possible between, behind, in front of, and at the sides of the two humps.
Finish with pieces of cut foam.
That’s it...
A very positive and comfortable first test run. I’ll see how things are from here. But at least it cost nothing other than some time.
jburner
Year: 2013 PCX
Post by jburner »
That works too. What’s your plan for the two holes?
aphid
Post by aphid »
jburner wrote:That works too. What’s your plan for the two holes?
For the time being I’m going to leave the two holes as they are, so that I can adjust the padding if I need to. Once/if I’m happy with the result I’ll stick a couple of patches over them.
