Mileage of your PCX
Re: Mileage of your PCX
Poor guy! I am sure that he collected some items from his trip that are not replaceable. At almost 40K miles on the bike it probably was going to have to have a few other things replaced soon enough, but otherwise he seemed to have managed very well on his trip. It is too bad that some people who have no regard for other people spoiled his trip. I wonder where he will find another top box like that one he had on his original scooter. That was some box!
Martin J
I've had mine from new since the beginning of June this year, and only have 550 miles on it. I've just done the first oil change as the mileage will start to increase steeply when I start a new job.
Yamaha 900 Diversion '96
Suzuki GS550E '81
Benelli TRK502 '21
Honda PCX 125 '18
Suzuki GS550E '81
Benelli TRK502 '21
Honda PCX 125 '18
big bear
- Color: silver
im up to 399 miles so far
big bear
- Color: silver
just put 18 more miles on the pcx its up to 417 now
- MikeP
- Color: White /red
Well as of Sept 4th 2018, I am up to 42505 km or
26411 miles. She still runs like a Singer sewing machine.
superandyp
Mines a 2016 with 12,000 bought it last June with 1200 miles on it. It's in need of a clutch bearing now.
big bear
- Color: silver
does the clutch bearing go bad every 12000 miles
- alx123
- Bangkok Rider
- Color: Fast White
Mine is at 28,000 kms (17,000 miles), bearing still okay.big bear wrote:does the clutch bearing go bad every 12000 miles
No.
superandyp
I think it is common for the bearing to get noisy. A lot of people have needed to change them out. Mine is making a racket
superandyp wrote:I think it is common for the bearing to get noisy. A lot of people have needed to change them out. Mine is making a racket
It happens but its not commonplace.
hikari2763
Just under 10,000 miles now, mine is a 2011 but, so far everything seems to be running great, my front tire is a little old, but otherwise seems pretty great. If I don't trade it in, I will keep using it as my standard commuter, but that is only going to be about 3-4K miles a year unless I get a different job.
WhiteJLY
- Color: Pearl white
My PCX is more than a month old. Had its first service 2 days ago.
450 km on the odometer. Average fuel consumption was 47.2 km/l. I think I averaged 75 km/h.
Sorry for the dirts on my photo.
- My PCX after its first service
- After 1st service.jpg (634.83 KiB) Viewed 4204 times
WhiteJLY
Malaysia
Malaysia
- alx123
- Bangkok Rider
- Color: Fast White
Really nice dash on the 2018. I love the wider tires too.
Mine currently at 28,000 kms (17k miles)
Thing Iv'e changed so far.
Tires @24000kms
Belt @24000kms
Rollers @24000kms
Gear oil @18000kms
Engine Oil every 6000kms
Variator and plate @28000kms
Clutch pads @28000kms
Rear brake shoes @28000kms
things needed to be done/change @30000kms
1.Valve clearance check
2. Front brake pads
3. time to upgrade suspension rear and front
Tires @24000kms
Belt @24000kms
Rollers @24000kms
Gear oil @18000kms
2. Front brake pads
WhiteJLY
What engine oil do you use? My mechanic told me to come every 2,000 km or every 3 months for an oil change. On the first service, I was told to change the final gear oil which according to the manual (checked after came back from service) should only be changed after 2 years.alx123 wrote:Really nice dash on the 2018. I love the wider tires too.
Tires @24000kms
Belt @24000kms
Rollers @24000kms
Gear oil @18000kms
2. Front brake pads
WhiteJLY
Malaysia
Malaysia
- alx123
- Bangkok Rider
- Color: Fast White
I'm just using the oil from HondaWhiteJLY wrote:What engine oil do you use? My mechanic told me to come every 2,000 km or every 3 months for an oil change. On the first service, I was told to change the final gear oil which according to the manual (checked after came back from service) should only be changed after 2 years.alx123 wrote:Really nice dash on the 2018. I love the wider tires too.
Tires @24000kms
Belt @24000kms
Rollers @24000kms
Gear oil @18000kms
2. Front brake pads
Manual says change every 6000 kms, so I really not gonna argue with it. As long as the oil level is at the recommended level, which i make sure to check every month, i dont really give it much thought until it's time to change again.
But changing often surely will not hurt your bike
Changing the gear oil at first 500 kms is ideal, as well as the first engine oil. After that initial 500kms, you can either follow the manual or change as often as your mechanic recommend. In my opinion
WhiteJLY
Ok, mine have the same "Jaso MB" certification which should be the same quality. I'll wait until 6,000 km then.
WhiteJLY
Malaysia
Malaysia
