Mileage of your PCX
Re: Mileage of your PCX
Poor guy! I am sure that he collected some items from his trip that are not replaceable. At almost 40K miles on the bike it probably was going to have to have a few other things replaced soon enough, but otherwise he seemed to have managed very well on his trip. It is too bad that some people who have no regard for other people spoiled his trip. I wonder where he will find another top box like that one he had on his original scooter. That was some box!
Martin J
Year: 2018
Post by Martin J »
I've had mine from new since the beginning of June this year, and only have 550 miles on it. I've just done the first oil change as the mileage will start to increase steeply when I start a new job.
Yamaha 900 Diversion '96
Suzuki GS550E '81
Benelli TRK502 '21
Honda PCX 125 '18
big bear
Color: silver
Post by big bear »
im up to 399 miles so far
big bear
Color: silver
Post by big bear »
just put 18 more miles on the pcx its up to 417 now
MikeP
Color: White /red
Post by MikeP »
Well as of Sept 4th 2018, I am up to 42505 km or
26411 miles. She still runs like a Singer sewing machine.
superandyp
Post by superandyp »
Mines a 2016 with 12,000 bought it last June with 1200 miles on it. It's in need of a clutch bearing now.
big bear
Color: silver
Post by big bear »
does the clutch bearing go bad every 12000 miles
alx123
Bangkok Rider
Bangkok Rider
Color: Fast White
Post by alx123 »
big bear wrote:does the clutch bearing go bad every 12000 miles
Mine is at 28,000 kms (17,000 miles), bearing still okay.
No.
superandyp
I think it is common for the bearing to get noisy. A lot of people have needed to change them out. Mine is making a racket
superandyp wrote:I think it is common for the bearing to get noisy. A lot of people have needed to change them out. Mine is making a racket
It happens but its not commonplace.
hikari2763
Post by hikari2763 »
Just under 10,000 miles now, mine is a 2011 but, so far everything seems to be running great, my front tire is a little old, but otherwise seems pretty great. If I don't trade it in, I will keep using it as my standard commuter, but that is only going to be about 3-4K miles a year unless I get a different job.
WhiteJLY
Year: 2018
Color: Pearl white
Post by WhiteJLY »
My PCX is more than a month old. Had its first service 2 days ago.
450 km on the odometer. Average fuel consumption was 47.2 km/l. I think I averaged 75 km/h.
Sorry for the dirts on my photo.
My PCX after its first service
After 1st service.jpg (634.83 KiB) Viewed 4201 times
WhiteJLY
Malaysia
alx123
Bangkok Rider
Bangkok Rider
Color: Fast White
Post by alx123 »
Really nice dash on the 2018. I love the wider tires too.
Mine currently at 28,000 kms (17k miles)
Thing Iv'e changed so far.
Tires @24000kms
Belt @24000kms
Rollers @24000kms
Gear oil @18000kms
Engine Oil every 6000kms
Variator and plate @28000kms
Clutch pads @28000kms
Rear brake shoes @28000kms
things needed to be done/change @30000kms
1.Valve clearance check
2. Front brake pads
3. time to upgrade suspension rear and front
WhiteJLY
Year: 2018
Color: Pearl white
Post by WhiteJLY »
alx123 wrote:Really nice dash on the 2018. I love the wider tires too.
Tires @24000kms
Belt @24000kms
Rollers @24000kms
Gear oil @18000kms
2. Front brake pads
What engine oil do you use? My mechanic told me to come every 2,000 km or every 3 months for an oil change. On the first service, I was told to change the final gear oil which according to the manual (checked after came back from service) should only be changed after 2 years.
WhiteJLY
Malaysia
alx123
Bangkok Rider
Bangkok Rider
Color: Fast White
Post by alx123 »
Tires @24000kms
Belt @24000kms
Rollers @24000kms
Gear oil @18000kms
2. Front brake pads
I'm just using the oil from Honda
Manual says change every 6000 kms, so I really not gonna argue with it. As long as the oil level is at the recommended level, which i make sure to check every month, i dont really give it much thought until it's time to change again.
But changing often surely will not hurt your bike ;)
Changing the gear oil at first 500 kms is ideal, as well as the first engine oil. After that initial 500kms, you can either follow the manual or change as often as your mechanic recommend. In my opinion
WhiteJLY
Year: 2018
Color: Pearl white
Post by WhiteJLY »
Ok, mine have the same "Jaso MB" certification which should be the same quality. I'll wait until 6,000 km then.
WhiteJLY
Malaysia
