dip sticks...
dip sticks...
I have a bunch of these if anyone wants one
- s-l300.jpg (55.93 KiB) Viewed 2698 times
- Limey
- Year: 16 Forza/16 PCX
- Color: Red/Maroon
Re: dip sticks...
Methinks I'll check the date!
Re: dip sticks...
Well don't be so quick to dismiss Limey
what if displacing the oil just circulates less oil more often... hummm what about that Mr. Fung?
Cheap skates love em so buy one today!
Re: dip sticks...
Re: dip sticks...
The above April fools day gag inflatable dipstick has be thinking there is something more here to draft.
What if one was to design something like this for all bikes? Tell me if you boys and girls get this
A float drives an indicator into a window on the grasp... would you buy this if it worked?
- dip1.jpg (38.75 KiB) Viewed 2663 times
Re: dip sticks...
Good one.
Dipsticks are so dumb, clearly there's a better solution.
- PCX150Rider
Re: dip sticks...
The crankcase "sight glasses" are really the way to go on motorcycles and scooters IMHO. It not only allows one to note the oil level but also examine the general appearance of the oil to see if it's looking ugly or is getting any water contamination (streaks of light color) from too many brief startups or not allowing the engine to run long enough to get up to operating temperature and let evaporation do it's thing.Dipsticks are so dumb, clearly there's a better solution.
- PCX150Rider
Re: dip sticks...
Look what Harley has. . . https://houseofharley.com/harley-davids ... 5-09A.htmlThe above April fools day gag inflatable dipstick has be thinking there is something more here to draft.
What if one was to design something like this for all bikes? Tell me if you boys and girls get this![]()
- easyrider
- Color: blk
Re: dip sticks...
"sucha deal"" 135.00PCX150Rider wrote:Look what Harley has. . . https://houseofharley.com/harley-davids ... 5-09A.htmlThe above April fools day gag inflatable dipstick has be thinking there is something more here to draft.
A float drives an indicator into a window on the grasp... would you buy this if it worked?![]()
Re: dip sticks...
Hey, I need one of those. That way I can twist around at a stop light and look down to check the temperature of the oil. But first I have to reach down and press that tiny button with my gloved hand. Yep, sounds like a winner.
Re: dip sticks...
"Final Sale - Non-Returnable"
That's all I'd need to know.
Re: dip sticks...
I like that eye portal GN! It does make you wonder why we have dip sticks at all. Perhaps since they have to drill an oil fill hole anyway a second one for an eye would put the bike out of my price range
Some things just make you say uh
- PCX150Rider
Re: dip sticks...
That concept reminds me of a fuel oil level gauge for a 275 gallon tank. It would probably work as long as the flotation device would drive the indicator bar vertically with no hang ups.A float drives an indicator into a window on the grasp... would you buy this if it worked?
At $14.95 it would probably sell with a ton of reviews and 4 out of 5 stars.
It seems like a more fail-safe gadget than an electric readout product. And if it sticks you can always try putting the PCX up and down on the center stand a few times to jog it loose.
Re: dip sticks...
I think a couple things would aid in fail safe operation... engine vibration and the fact its saturated in oilPCX150Rider wrote:It would probably work as long as the flotation device would drive the indicator bar vertically with no hang ups. At $14.95 it would probably sell with a ton of reviews and 4 out of 5 stars.It seems like a more fail-safe gadget than an electric readout product. And if it sticks you can always try putting the PCX up and down on the center stand a few times to jog it loose.
- PCX150Rider
Re: dip sticks...
If it's a "top read" gauge then a spiral type contraption that would rotate as the float rises or sinks would be required. I think I've seen lawn mowers that have this type of gauge in gas tanks.It needs to connect to the push rod and must be made of a buoyant material that does not degrade from heat or petroleum. If hollow be sealed around the core and still make the connection to the rod. If solid still be buoyant. I can't yet see the float design in my minds eye.
If it's a "side read" or "section view" gauge then it could just be a float that's hard mounted to the indicator bar or rod in the appropriate location.
Two challenges either way are going to be keeping the gauge mechanically sealed and eliminating any interference in the range of movement.
Re: dip sticks...
Why not just live with a dipstick and think about things less?
Re: dip sticks...
No, that would spoil the game. We MUST overthink everything. How about a dip stick like the old pole that had a bell at the top. Squeeze it hard enough and the bell rings...and you get a prize. Hmmm...maybe you can get a smiley face.
- JohnL
- Ozzie Old Fart
- Color: Dark Red
Re: dip sticks...
There are dip sticks, and then there are DIPSTICKS
- PCX150Rider
Re: dip sticks...
Jolly good then. . .it's settled!There are dip sticks, and then there are DIPSTICKS![]()
Re: dip sticks...
JohnL wrote:There are dip sticks, and then there are DIPSTICKS![]()
Ive noticed a few.
