Torque Value in ft. lbs. for Rear Brake Cable Fastener
PCX150Rider
Post by PCX150Rider »
Unless I missed something. . .I can't find the torque value for that 8mm fastener that has to be removed and reinstalled on the rear brake cable bracket when you pull the Oil Strainer Screen for maintenance. Depending upon the fastener situation it varies in the Torque Values chart on page 1-11 of the SM. It could be 16 ft. lbs, maybe 20 ft. lbs. Seems a little high. Anyone know?
Wanted to do my 600 mile oil change and clean the strainer today or tomorrow.
Hope everyone is enjoying this weekend and getting some riding in. :roll: :D 8)
Re: Torque Value in ft. lbs. for Rear Brake Cable Fastener
I'm late for church but will confirm later :D
PCX150Rider
Thanks. . .Put a good word in for us all will ya? There's a whole lot of disharmony on the planet right now. ;)
PCX150Rider wrote:I can't find the torque value for that 8mm fastener that has to be removed and reinstalled on the rear brake cable bracket when you pull the Oil Strainer Screen for maintenance. Depending upon the fastener situation it varies in the Torque Values chart on page 1-11 of the SM. It could be 16 ft. lbs, maybe 20 ft. lbs. Seems a little high.
I see what you mean, 'rear brake cable clamp bolt' being one of the crankcase cover bolts does not have a torque value spec mentioned specifically. It's to be treated as one of the 10 pulley/clutch cover bolts in torque value and I haven't found those values yet either. Could be anywhere in the SM :x I have removed and replaced the CVT cover many times and not sought after the torque value on those 10 bolts but because you ask :D
WARNING! 7 ft lb is going to strip, 4 ft lb starts twisting the bracket and pushes the limit for these CVT cover bolts. I will say 2.5 ft lbs does the job but at that point you should be using an inch pound torque wrench. Seriously I haven't used a torque wrench on these until today since you peaked my curiousity. You should just turn until snug and then bump them ever so slightly more, like maybe 1/16 or 1/32 turn more. That will be close to 3 ft lbs pressure and plenty to secure the CVT cover bolts :D
Admin delete thread before somebody tries to put 16 foot pounds or even 7 ft lbs on the CVT cover bolts :lol: Don't worry about me, I didn't strip anything in this exercise. I sneaked up on it until I realized these were no were near 7 ft lbs torque. The SM is of no help with this requested torque value... weird.
Just nip it up a teeny bit. It's not a NASA issue really.
PCX150Rider
Homie - Then I guess I didn't overlook it. . .. :roll:
So idiot that I am when I went to use my torque wrench I discovered that it starts at 20 ft. lbs. and goes up from there. It's more of a heavy duty automotive type one. I'll have to pick one up that deals with the lower torque values. :o
That being said I kind of went with my instincts from working on metric bikes over the years and carefully tightened the oil drain plug, the brake cable bracket bolt, and the strainer cap. I will say the strainer cap did give some resistance on removal and I used the leverage of the torque wrench handle as a persuader to finally get it to spin. . .and without rounding anything off. You were absolutely right about the fuzz. And it cleverly tucks itself up near the rubber piece the screening is molded into as well. There was some "greyish" graphite looking material that came off on the paper towel when I cleaned off the screen. . .not particles. . .just very fine pencil lead colored stain. I thoroughly cleaned off the screen needless to say and reinstalled with the 17mm socket. Not really any compression room there. Once you get the screen, spring, and cap assembly spun to the mating surface it's hardly a twist after that and it's on tight. I did put a little new oil on that cap o-ring before reinstalling. 8)
As an added note I made sure the brake cable was properly routed and not out of plan when I reinstalled. ;)
The SM said replace 1 quart of the recommended oil if you drain the oil and remove the strainer. . .which I did. I found the level to be a little bit higher though than the high level mark on the stick upon measuring it after running the motor for a bit. I definitely got at least 800 ml of old oil out of the oil drain pan (poured it back into the empty Honda oil bottle) and there was some residual still in it. So by adding the quart I know it couldn't be that much more than what came out. Seems like a vague situation. :roll:
Here's what I did when I drained the oil. . .unconventional and don't recommend it to others but I walk the edge sometimes. The motor was warm and the exhaust pipe was warm. Not hot enough to burn me but close. I have a plastic triangular oil drain pan. I put the PCX on the side stand. I removed the oil filler cap, cleaned it and put it aside (the o-ring was fine). I loosened the oil drain plug with my 12mm socket wrench just enough to loosen it by hand without oil coming out yet. I carefully fit the one of the angular ends of the oil pan under the PCX in such a way that when I was loosening the drain plug by hand the oil spilled right into the pan and on nothing else. Then wiped off my hand and the oil plug/washer to reinstall later. When the draining stopped I went around to the kickstand side of the PCX and while carefully holding the left handlebar and passenger grab rail I let the PCX lean to the starboard side and could hear more oil coming out. I did that until it stopped. . .did it again. . .heard it a gain. . .and did it one more time until it had definitely stopped. I proceeded to wipe off the drain hole and hand tighten the plug before I pulled out the drain pan. Then I tightened the drain plug carefully with the socket wrench. Note that since the oil drain pan was plastic it could "give" a little bit if there was contact with the frame or exhaust pipe etc. . .when I lean it over. :geek:
Next thing I did was put the PCX on the center stand and got ready to remove the brake cable bracket bolt and the strainer cap. The 8mm bracket bolt came off easy and I just tugged down on the cable a little to allow more access to remove the strainer cap. I then slid the oil pan back under the PCX strainer cap penetration. Using my 17mm socket with the extension I first had trouble trying to loosen the cap. So I tried using my torque wrench (much longer handle) with the socket adapter and low and behold the cap let go and I was then able to hand loosen the assembly. As stated above I found the "fuzz" and some other stuff. There also seemed to be some red paint that was applied along the lip of the cap like a factory reference mark or something. While the strainer assembly was removed (and with the PCX still on the center stand) I again carefully grabbed the left handlebar and passenger grab rail and tilted the PCX towards me a bit (to the port side) and could hear more oil pour out. I repeated the effort a couple of times to allow things to settle in the base of the motor and to enhance the amount of oil removed as much as I could. The next time I do this I may take it off the center stand first and then do the tilt. . .but like I said sometimes I live on the "edge". :lol:
So after 612 miles my PCX is running great with fresh oil and a clean screen. I hope being a little over the high oil level mark on the stick isn't a mortal sin. If I have to I can drain a little out but it seems OK. Will think about. . .. :geek:
PCX150Rider wrote:Homie - Then I guess I didn't overlook it. . .. :roll:
What edge?
PCX150Rider
What edge?
New discoveries and inventions are unveiled by pushing the "edge" of the envelope, getting into the sticky part, and going beyond that edge into the "unknown". It's when you're in the "unknown" that you either succeed or fail. . .succeed by going forward and creating another stepping stone for humanity to reach out to. . .or fail and return to the familiar, the common, the rock of what is accepted as reality, or a huge mess to clean up. o_O :? :o :lol:
PCX150Rider
Wait. . .there's more! :lol:
Just did about 40 miles and it ran fine. No problems I could detect. Everything seems OK. Now watch the crap hit the fan. . .. (just kidding) :lol:
Will check the oil level again next weekend.
One thing I will mention is that the engine braking seems a little more noticeable. Not sure if I'm delusional about it or the 10w-40 weight oil makes a difference. :roll:
Next thing to buy will be a torque wrench that is rated for lower values. Maybe something like this http://www.homedepot.com/p/Husky-5-80-f ... /206096361 :geek:
Great job! You found the factory fuzz :lol: I'm guessing they use fuzzy gloves or there is a shop rag being used to wipe something on assembly. Please do not over fill the engine oil. I would have to check but unlike my Buell with a oil pump serving the life blood the GY6 probably splashes from a spoon on the crank somewhere. This would make for some excessive engine braking and a much harder working engine if you have too much oil in the crank case. Again I would have to look at parts of the SM I have never been to know for sure.
PCX150Rider
Okay. . .so I thought it over and I'm going to drain enough oil out to meet the "full" level on the dip stick with the engine warm.
What did I learn from this? You can't always believe what you see. . .. Although the SM says to add 1 US quart of oil (ref. SM page 3-12), if you drain out the old oil and remove the strainer, it isn't necessarily true to the letter. Some oil will remain in passages etc.. . . .within the cavities and void spaces of the engine. . . and so when you add oil during an oil change it's best to add most of it. . .say around 700 ml at first. Then check the dipstick and see what that indicates. If it's below the "full" level then perhaps add a little more or if it's close to "full" it would be OK to leave it "as-is". That being said do the occasional oil level checks and add as needed moving forward as mileage accumulates. :geek:
Even though I did tilt the PCX to help oil find it's way to the drain hole and strainer penetration it just wasn't enough to remove 100% of the oil in the engine. As stated previously I was able to get about 800 ml of the old oil out of the engine. . .which basically is the recommended amount to add on a routine drain and fill operation. ;)
Use a syringe and pipe or an old turkey baster to get the oil out
you you wrote:Use a syringe and pipe or an old turkey baster to get the oil out
Or if you are a little neuritic (WARNING - I'm not endorsing this at all for PCX because I haven't thought it thru) I do this to the Buell at the risk of having to prime the oil pump but get away with it every time and always check to see oil flow is good before walking away after change > Start and idle the engine for 15 seconds o_O :lol: Tosses all the residual oil to the drain but can get messy if you forget to cover or control the drain port. Again I made this one up and have no idea what could happen with a PCX running with no oil for a few seconds. I assume it to be no different than the few seconds it takes for oil to get moving after the little engine has sit for a while. The critical element of this craziness is the rings in those seconds so think about that with me for a moment. Certainly warm the bike before dropping the oil and consider the hot gases on the cylinder walls with no more oil coming up from below for those seconds, might no be worth a little dirty oil left in the system. I think I will stop doing that with the Buell :lol:
djbass
Year: PCX150, 2015
Post by djbass »
The remaining 1-5% of the old oil does not affect the properties of the new oil and engine life. A drain in the zero oil system with engine start is really bad.
Don't run your PCX without any oil.
FFS.
you you wrote:Don't run your PCX without any oil FFS.
:lol:
PCX150Rider
Just got back and read all these great suggestions. :)
I actually did use a syringe (same one I use to put final drive gear oil in my Roughhouse. . .clean though) and what I think was either extra tubing from my old fish tank or maybe from a battery I got some years ago. Glad I hang onto that crap. Just cut it a bit longer than the dip stick, stuck it on the end of the 10 ml syringe and good to go. The only real PITA was the fact that the tubing still had some coil in it which made me have to use extra care inserting and removing it. Too much in and it would start to coil up above the oil level and I'd get a lot of air. . .or pulling it out I had to make sure I got it aimed into the plastic cup before I emptied. So at the end of the day I ended up with the oil level right at the full line. :D
FWIW still getting around 106 MPG on a regular basis. Trying to get used to the awkwardness of ordering $2 worth of gas when I get to half a tank. . .makes the gas station clerks grin and look to see what I'm riding. :geek:
youyou... I deserved that :lol: so I wanted to elaborate on where my neuritic monkish behaviour came from... BRITAIN of course! Those obsessive compulsive Brits, we had to ban them from the Buell forum for freaking us out :lol: :lol: :lol:
homie wrote:youyou... I deserved that :lol: so I wanted to elaborate on where my neuritic monkish behaviour came from... BRITAIN of course! Those obsessive compulsive Brits, we had to ban them from the Buell forum for freaking us out :lol: :lol: :lol:
Britain, where is that? There's no such place.
Did you, in your own way, mean Great Britain? :lol:
djbass wrote:The remaining 1-5% of the old oil does not affect the properties of the new oil and engine life. A drain in the zero oil system with engine start is really bad.
Thank you. Praise the Lord... :D :lol:
