how long do i have once clutch bearing makes noise
eggman
to it is unridable
Re: how long do i have once clutch bearing makes noise
Well, I heard the noise when the bike had 7,000 miles but until it reached 10,000 miles we didn't do much more than keep asking the service department what that noise was. Finally, the mechanic called the other mechanics and they all agreed that there was definitely something wrong. Others may not make it that long, but then at 10,000 miles the bearings were completely shot on our bike, so I wouldn't wait that long if I were you.
eggman
may just sell it i wonder if i can get $1400 as is
Or you can spend $30 and buy the replacement kit.
http://www.bikebandit.com/oem-parts/det ... sch=794095
eggman
i suck at working on a pcx. ps i cant ear the bearing wen im rideing it
I doubt that it will take the mechanic an hour to do it.
My rear wheel makes a noise when turned or I am wheeling the bike - until the cluthc engages. Not as bad as some but noticeable. Passed it's MOT though as it's not part of the checks, but they may get fussy about bearings and the wheels/safety.
Hard to sell any vehicle when it is "making a funny noise".eggman wrote:may just sell it i wonder if i can get $1400 as is
Any local scooter guys / shops that could swap out this part for you?
eggman
then it sucks to be me because they will only here it with it on stand and engine off. but idont nee bad karma so ill tell em about the noisefish wrote:Hard to sell any vehicle when it is "making a funny noise".eggman wrote:may just sell it i wonder if i can get $1400 as is
eggman
could it need any more parts then these http://www.cheapcycleparts.com/oemparts ... set-driven
eggman
do you think i can get 12 hundred for it as is? im going to get the new honda rebel she has 30 hp out of just 300 cc
That's it, I keep one on hand just in case but obviously not all are bad or going bad. There's a new part number for after 13's and it hasn't been established yet if the old part# fits newer PCX. I think you can get 1200.00 There was once a guy who offered one for 800 but he looks crazy
Never saw one that low.
- unnamed.jpg (122.06 KiB) Viewed 1878 times
eggman
if i dont spin the wheel when bike is off it makes no noise at all and runs great i have 1300 hundred in the bike at this point so ill be losing a hundred i think i put like 5000 miles on it
You did the labor yourself last time you had a bad one didn't you? Did you grease it up per the instructions?eggman wrote:if i dont spin the wheel when bike is off it makes no noise at all and runs great i have 1300 hundred in the bike at this point so ill be losing a hundred i think i put like 5000 miles on it
eggman
nah i had it done i suck at fixing the pcx even thou i can fix a lot of cars
I ask because I wonder if they put the 7 grams of grease these things require prior to installation. They are not plug and play out of the box and the bearings are not dry but still not per the SMeggman wrote:nah i had it done i suck at fixing the pcx even thou i can fix a lot of cars
