fuel cap wont open
- halluinoid
- Year: 2018
- Color: blue
fuel cap wont open
turned the switch to SEAT FUEL (7 o'clock) push the fuel side of the rocker that labelled FUEL/ SEAT
fuel lid remains closed
I cant get it to open
2018 Honda Forza 300cc
Re: fuel cap wont open
It is a safety feature. If you are not smart enough to get the fuel in then you should't be riding!
Just kidding but I had an elderly friend who could not start his car because he had forgotten he had to have his foot on the brake to turn the key.
He was at the beginnings of Alzheimers. Later he did start his car and I had to jump on my scooter to track him down. Sad case.
Try jiggling the key, the bars and the fuel flap door. Gently tap on everything also.
Is the 2018 a mechanical system like the earlier 2014's?
- halluinoid
- Year: 2018
- Color: blue
I assume so, it does appear that way, looks like I'm going nowhere until this is sorted
- Yorkie150
- Year: 2018/19
- Color: RED
push the flap down slightly as you press the switch .....the dirt/grime '' gremlins are everywhere in this weather and can make these catches stick a bit
Had the opposite problem with mine, it wouldn't stay shut.
Jammed cardboard in the latch and that did the trick.
+1 on the wiggle and jiggle to open reluctant flaps...
Get on the phone to the dealer pronto
I carry a pocket knife just for that possibility. Sometimes the mechanical switch works but the door sticks. A thin screwdriver will also work. Push the fuel button while gently prying the door up.
If that does not work you may end up taking the plastic off that holds the fuel door and spraying some wd40 in/on the cable.
- halluinoid
- Year: 2018
- Color: blue
bearing in mind I have never seen this door open yet...... while gently prying the door up? from which side ?
Do you have the keyless dongle in you pocket and does it have working batteries? Does it have a fuel button?
I did not know it was very new, call your dealer.
- Color: Blue
Press the fuel flap button and at the same time press the plastic behind the hinge of the flap, it will open a few times then stop again.halluinoid wrote:bearing in mind I have never seen this door open yet...... while gently prying the door up? from which side ?
- Fuel.JPG (52.09 KiB) Viewed 5129 times
- halluinoid
- Year: 2018
- Color: blue
didn't work
straight to petrol station, 10L straight into the tank, it's FULL and the vehicle is at WARP FACTOR 8, thanks to all, back in business
SUCCESS! Mel46 I now carry a pocket knife just for that possibilityMel46 wrote:I carry a pocket knife just for that possibility. Sometimes the mechanical switch works but the door sticks. A thin screwdriver will also work. Push the fuel button while gently prying the door up..
Now take it to your dealer and tell them to FIX it.halluinoid wrote:didn't work
