push the flap down slightly as you press the switch .....the dirt/grime '' gremlins are everywhere in this weather and can make these catches stick a bit
Had the opposite problem with mine, it wouldn't stay shut.
Jammed cardboard in the latch and that did the trick.
+1 on the wiggle and jiggle to open reluctant flaps...
I carry a pocket knife just for that possibility. Sometimes the mechanical switch works but the door sticks. A thin screwdriver will also work. Push the fuel button while gently prying the door up.
If that does not work you may end up taking the plastic off that holds the fuel door and spraying some wd40 in/on the cable.
Mel46 wrote:I carry a pocket knife just for that possibility. Sometimes the mechanical switch works but the door sticks. A thin screwdriver will also work. Push the fuel button while gently prying the door up..
SUCCESS! Mel46 I now carry a pocket knife just for that possibility
straight to petrol station, 10L straight into the tank, it's FULL and the vehicle is at WARP FACTOR 8, thanks to all, back in business
Now take it to your dealer and tell them to FIX it.
