Oil going low
retry
Color: silver
Oil going low
Post by retry »
Hi everyone,
recently noticed, that oil in my pcx125 (31k miles on the clock, most of milage is done on 65mph, so hi revs)) started to go low , so i looked around for oil leaks -nothing, tried to start cold and check for exhaust smoke- nothing, acceleration didn't change, decided to note down how much oil i add when topping up and it is 500ml per 1000miles, tried to find oil consumption figures for pcx 125 - didn't succeed. From what i think it is A LOT of oil ..
The only thing i can think off is that i done valve clearance adjustment 20k miles ago - coz engine sounds good see bo reason to do it, but maybe im wrong and valve clearance is to blame?
Re: Oil going low
My vote for cause of oil consumption: "125cc at 65mph for 31,000 miles"
Don't think valves are involved here.
retry
Color: silver
Re: Oil going low
Post by retry »
it is more 60-65 mph depends whether I'm going uphill or downhill.
so if I always do long runs on full throttle it burns oil?
Re: Oil going low
retry wrote:it is more 60-65 mph depends whether I'm going uphill or downhill.
How many oil changes in those 31,000 miles?
retry
Color: silver
Re: Oil going low
Post by retry »
oil change every 1.5-2k
Re: Oil going low
Your consumption is significant. ....probably not completely out of order considering having been run 31,000 miles at WOT.
At what mileage did you notice this consumption?
A valve check at the recommended miles is a good idea.....but won't fix your oil use. Riding habits did that.
The Poacher
Re: Oil going low
Post by The Poacher »
32000,flat out, day in,day out, beginning of the end I feel...
Leo Vince GP Exhaust
retry
Color: silver
Re: Oil going low
Post by retry »
so the only option is bore kit ?
retry
Color: silver
Re: Oil going low
Post by retry »
fish wrote:Your consumption is significant. ....probably not completely out of order considering having been run 31,000 miles at WOT.
around 2000 miles ago
The Poacher
Re: Oil going low
retry wrote:so the only option is bore kit ?
Or get rid!
MikeP
Color: White /red
Re: Oil going low
Post by MikeP »
Retry, your not alone in your experience. I have a 2013 150 PCX, now up to 51,000km or about 30,000miles. I find the need to top up my oil to the sum of about 250ml every 1000km. Or 50ml per fil up roughly. I recognize my riding habbits have contributed to the wear, but figure since I just love riding this scoot I will just enjoy it. When my oil consumption exceeds my fuel consumption, time to rebuild the engine. :D Already have the parts in the garage for when that day comes.
Personally, I would not worry about it, just check your oil every fillup. If you plan on rebuilding the engine, you could start pricing out the parts and some how too videos. The manual is a must as well.
Just my 2 cents worth. Personally, I am set on rolling 100,000km.
retry
Color: silver
Re: Oil going low
Post by retry »
MikeP wrote:Retry, your not alone in your experience. I have a 2013 150 PCX, now up to 51,000km or about 30,000miles. I find the need to top up my oil to the sum of about 250ml every 1000km. Or 50ml per fil up roughly. I recognize my riding habbits have contributed to the wear, but figure since I just love riding this scoot I will just enjoy it. When my oil consumption exceeds my fuel consumption, time to rebuild the engine. :D Already have the parts in the garage for when that day comes.
Man thank you for your reply!
Could you advise me what parts need to be replaced? Rings on pistons or piston with the rings+ cylinder head ( due to cylinder wall wear)?
i have full manual and some experience, the only thing i don't have- is time :))
72 pounds and 2-3 days of work with some beer :)
https://www.ebay.co.uk/itm/Cylinder-Kit ... 9955a59a36
retry
Color: silver
Re: Oil going low
Post by retry »
Sorry mistake not cinder head, but block :)
MikeP
Color: White /red
Re: Oil going low
Post by MikeP »
Looks like you are from the UK judging from your link. The
Kit you linked has it all. I also included a timing chain, timing chain tensioner as I hear they are prone to go after 50k km. But the kit is a solid start. Just source out a supplier for the odd bits and pieces you may need while doing the job. Being in Canada, I use babbittsonline. Have been very happy with them and they have the same schematic breakdown as my Honda dealer. Makes part identification a breeze.
MikeP
Color: White /red
Re: Oil going low
Post by MikeP »
One last thing, just my opinion, stick with Honda factory parts. Saves compatibility issues.
retry
Color: silver
Re: Oil going low
Post by retry »
MikeP wrote:Looks like you are from the UK judging from your link. The
Kit you linked has it all. I also included a timing chain, timing chain tensioner as I hear they are prone to go after 50k km. But the kit is a solid start. Just source out a supplier for the odd bits and pieces you may need while doing the job. Being in Canada, I use babbittsonline. Have been very happy with them and they have the same schematic breakdown as my Honda dealer. Makss part identification a breeze.
Thank you so much, especially for the tip with chain and tensioner.
Re: Oil going low
Hi retry! :) I'm glad to read that you're getting some very helpful advise from experienced members, They Rock! Please show some love back by Adding your location to your profile (simple directions are below my post).
Have fun tooling and please keep us updated :D (+ pics)
To others who have not added their locations yet, please do the same. "Help Us to Help You" ;)
Re: Oil going low
Speaking of oil, I just now finished changing the oil on my PCX. I dont have a stand to put the bike on when changing the oil or doing maintenance, but it had to be done, soooo...
When I change the oil on my bikes I note it on some white duct tape I put on the swingarm. As long as you clean the arm to remove all grease, it sticks quite well.
oil change label.jpg (111.68 KiB) Viewed 7390 times
Re: Oil going low
[quote="Mel46"]Speaking of oil, I just now finished changing the oil on my PCX. I dont have a stand to put the bike on when changing the oil or doing maintenance, but it had to be done, soooo...
[/quotei]
I write the same on final blank pages of owner's manual, kept under the seat.
Eiron
Color: Poseidon Black
Re: Oil going low
Post by Eiron »
+1 on this info.
One other suggestion might be to switch to a heavier weight motor oil to help slow consumption. You might see a very slight decrease in fuel efficiency, but I doubt it if you're riding WOT most of the time. I used to run 15W-40 conventional oil in my 1980 Honda Super Cub here in Northern Colorado without any issues other than slow starts in sub-freezing temps. Similarly, I've been using 15W-50 full synthetic in my PCX for the past few years. I'm thinking of changing over to 0W-40 for a little better MPG, but it's not the best choice if you're trying to limit consumption.
