New belt making slight squeal low speed
accyuklad
- Year: 2010
Mostly when I'm slowing down there be maybe 2-3 second squeal at around the 10-20mph mark
Old belt was very worn out and I fitted new belt and the variator did look a bit worn out didn't look shiny either
Is there a chance variator is causing the issue just strange since having oem new belt I got this problem but it not effecting me to get upto speed or anything
Re: New belt making slight squeal low speed
Did you replace the variator as well? If not, it will take the belt a bit of time to adjust to the grooves in the old variator.
accyuklad
- Year: 2010
No didn't replace variator as I didn't realise till I changed belt so it seems that's on my list and my rear clutch bearing is knacked so after get that sorted sometime aswell
The drive faces of the variator can get glazed with rubber, or the rubber on a variator may have gotten oils on it. I'd take them out and wipe the belt and variator faces with a dry cloth. Do not use oil. If you feel like using a bit of fluid to help scrub, use alcohol and make sure it evaporates before reassembly.
Make sure you tightened to spec and that your spacers are in the right place too. A loose belt from an improperly tightened variator can squeak.
accyuklad
- Year: 2010
well person I brought from clearly never looked after it
as belt was ready to rip apart as it was cracked everywhere and wouldn't go past 60mph and variator doesn't look shiny as dots on it
clutch bearing is gone as it makes a noise but leaving it till it gets worse
going to do valve clearance next week
brought a replacement variator waiting till belt or clutch needs replacing saves me doing it more then once lol
retry
- Color: silver
New belt is Geniune honda ?accyuklad wrote:Mostly when I'm slowing down there be maybe 2-3 second squeal at around the 10-20mph mark
retry
- Color: silver
Clutch bearings will make noise again after 2-3 months after replacement, so just replace them 1 time a yearaccyuklad wrote:well person I brought from clearly never looked after it
brought a replacement variator waiting till belt or clutch needs replacing saves me doing it more than once lol
Belt in bad condition has no effect on the speed of your bike, probably your rollers did wear off and lost weight, so your max speed reduced
- zroger73
- Color: Bronze
A worn belt will absolutely limit top speed.retry wrote:Belt in bad condition has no effect on the speed of your bike...accyuklad wrote:as belt was ready to rip apart as it was cracked everywhere and wouldn't go past 60mph...
The sliding half of the pulley on the variator can only move a limited distance. As the belt wears and becomes thinner, it will ride lower in the vee formed by the two halves of the front pulley. The position of the belt on the rear pulley is determined by the tension of belt which is a factor of its length and where it rides in the front pulley. A worn belt results in a numerically higher gear ratio which limits top speed.
+1
That would be the first thing I would change if my top end started going down.
+1
Can I have spec of screws at front and rear variator when tightened ?maddiedog wrote:The drive faces of the variator can get glazed with rubber, or the rubber on a variator may have gotten oils on it. I'd take them out and wipe the belt and variator faces with a dry cloth. Do not use oil. If you feel like using a bit of fluid to help scrub, use alcohol and make sure it evaporates before reassembly.
