accyuklad
Posts: 73 Joined: Tue Apr 30, 2019 5:59 am
Year: 2010
Post
by accyuklad » Tue Apr 30, 2019 6:01 am
got a issue I just noticed I can wobble my wheel slightly on the rear wheel
does this mean the transmission drum bearing side as gone that should be holding it central or is this normal
accyuklad
Year: 2010
Post
by accyuklad » Tue Apr 30, 2019 8:09 am
hes video when its off the ground there abit of movement and when I sit the wheel to the ground its makes a gap and still as some play
I know centre stand mounts broke I had to use a wood plank and jack
https://www.youtube.com/watch?v=sTC1GXcyGC4
im guessing this be the bearing on the drum area or is this normal or could it be the bearing on the arm that's allowing it to move
Posts: 6964 Joined: Tue Nov 13, 2012 5:13 pm
Post
by Mel46 » Tue Apr 30, 2019 11:06 am
accyuklad,
Please go into your profile and add your general location. It helps us help you better. For example, in the United States there is no 2010 model.
accyuklad
Year: 2010
Post
by accyuklad » Tue Apr 30, 2019 12:04 pm
Is there a chance the spindle on the wheel might be put on incorrect called collar 42311KWN900
I only noticed it today when I was doing a service as I brought it 2 days ago second hand
accyuklad
Year: 2010
Post
by accyuklad » Tue Apr 30, 2019 1:18 pm
I'm going to take arm off tomorrow and see why there's movement and check if it's do with the collar as I can't understand why would it move
accyuklad
Year: 2010
Post
by accyuklad » Tue Apr 30, 2019 4:11 pm
Got a feeling it's the axle bearing in the transmission box
Posts: 10002 Joined: Sat Jun 30, 2012 5:37 pm
Post
by you you » Tue Apr 30, 2019 4:46 pm
I does to innit.
accyuklad
Year: 2010
Post
by accyuklad » Tue Apr 30, 2019 4:55 pm
Hope it's not going to cost alot to repair going to after get a quote
accyuklad
Year: 2010
Post
by accyuklad » Wed May 01, 2019 2:37 am
£50 for bloody 3 bearings and oil seal for the drum side
just hope labour isn't more then £60
Post
by Mel46 » Thu May 02, 2019 9:25 am
If a bearing/bearing collar has to be pressed out and the new one pressed in, that part of labor is usually sent out to be done, so expect that as an added expense in the labor costs.
accyuklad
Year: 2010
Post
by accyuklad » Thu May 02, 2019 1:58 pm
Garage going to have a look and see if it actually fine or not and he said it cost 60-80 if it does need doing with me giving the bearings
accyuklad
Year: 2010
Post
by accyuklad » Fri May 03, 2019 4:27 am
I never thought about checking but but on wheel and it was loose
Brendan
Posts: 11 Joined: Tue Apr 09, 2019 1:06 pm
Post
by Brendan » Fri May 03, 2019 5:05 am
accyuklad wrote: I never thought about checking but but on wheel and it was loose
Did you make a mistake here? What is "but but"?
Posts: 7768 Joined: Tue Dec 06, 2011 7:54 pm
Post
by gn2 » Fri May 03, 2019 1:42 pm
Brendan wrote: What is "but but"?
It means the engine is running.
But but but but but but but but but but but but but but but but but but but but but but but but but but but but but.......
Post
by you you » Fri May 03, 2019 3:19 pm
Brendan wrote: accyuklad wrote: I never thought about checking but but on wheel and it was loose
My brother.
accyuklad
Year: 2010
Post
by accyuklad » Sat May 04, 2019 9:06 am
no stupid phone I had always changes letters lol
post to be the nut
