Chrome handlebars and steer head top.
Hi, I don't like the chrome bits(handlebar, bar clamps, and steer head) Is there an aftermarket company that makes black ones?
Re: Chrome handlebars and steer head top.
Welcome aboard!! Sure we can assist
but it would be helpful if you added your location to your profile first. Then we'll "steer" you in the proper direction.
Look below, I have directions to get that done. Thanks.
Thank you
Here's one website others have successfully ordered from.
https://bikerzbits.com/honda/pcx/bikers/
Fam,...can color bars be found anywhere in the U.S.? Or just overseas?
Another website members successfully purchased from: is powerbypcx. Check his thread on our forum, nice stuff and discount is offered to our forum. Look, read, drool
viewtopic.php?f=14&t=208
- NADman
Paint - Powdercoat ????
- k2apache6.0
I did this a while back bikerz accessories. And used a Yamaha R1 caliper plug to dress up the center nut. The long bar in center was added, cut down to fit a clock and painted black and later replaced with a Koso electrical RPM gauge. I also cut down the adjustable height clamps and modded the windscreen to allow a more forward and lower (2" lower and 1.5" further forward than gthe stock chrome handlebar) to put a little more weight on the front wheel and a less 'sit up and beg' riding position. It feels roomier now and the handling benefitted slightly into the bargain.
- P5230381.JPG (144.68 KiB) Viewed 6731 times
- P5050228.png (651.51 KiB) Viewed 6731 times
My PCX mod build here..
- k2apache6.0
Heres the one with the Koso RPM gauge installed instead of the clock
- koso mod.JPG (60.28 KiB) Viewed 6730 times
- k2apache6.0
Nah, I'm not one to wait around for others. It's rattle can 'Krylon max', it has a primer built in. Its been well over a year now and holding up well. I used 320 grit wet and dry before painting to give it some 'purchase'. If it needs doing again down the road I'll simply do it again. I never get bored messing with stuff anyways.NADman wrote:Paint - Powdercoat ????
- NADman
#1 Rattle Can all the way. Cheap and easy (like me) to do and redo.k2apache6.0 wrote:Nah, I'm not one to wait around for others. It's rattle can 'Krylon max', it has a primer built in. Its been well over a year now and holding up well. I used 320 grit wet and dry before painting to give it some 'purchase'. If it needs doing again down the road I'll simply do it again. I never get bored messing with stuff anyways.NADman wrote:Paint - Powdercoat ????
- k2apache6.0
That reminded me of another famous political quote
Gladstone said to Disraeli,
"I predict, Sir, that you will die either by hanging or of some vile disease".
Disraeli replied, "That all depends, sir, upon whether I embrace your principles or your mistress."”
