Remove the valve cover and....
I have to say that ease of maintenance is a big plus for those who take care of their own machines in lieu of paying a professional mechanic to do it.
There are those jobs that require special tools but are more the exception than the rule I think. Your Like and Liberty were a good value when it comes to DIY.
If I may I'd like to digress a bit here . . ..
As I've mentioned before, I'm in the process of deciding which direction to go in on my next scoot. So far the XMax looks really good considering no new Forza will be available anytime soon but the extra features of ABS, Traction Control, and the fancy display modules and keyless ignition and so forth concern me as to how well they will hold up in the long run. I've seen in cars where ABS will crap out after a number of years due to contact corrosion or pumps failing. The brakes will still work though . . . just no ABS. I ask myself is it really worth the extra money for something that's just going to leave you at square one eventually anyhow. As far as Traction Control I can see it's usefulness . . . especially in Moto GP Racing . . . where appropriate power delivery to the rear wheel is of the utmost importance but I don't plan on doing that kind of racing with that kind of machine and engine horsepower.
Salt air, industrial pollutants, and humidity can also effect micro circuitry. I remember back in the '80s the "word on buying used" was to be "Never buy a car that was owned by a smoker because the acids from the smoke effect the electronics".
One other thing to consider is heated garage vs non-heated garage. Sometimes when the thermometer drops into the sub-zero range it makes me wonder what it does to LCD displays over an extended time and multiple Winters. They will get sluggish until they warm up . . .. Extreme cold just can't be a good thing for them.
The SMax still gets a lot of the boxes checked for what it offers in my view compared to it's bigger brother. It's less sophisticated yet high tech, easy to work on, $2K cheaper, and will do over 70 MPH with ease for mile after mile. It's main issue though is the seat. It's comfortable if it fits being more like a "King and Queen" seat. That said it is rated to carry 353 lbs. . . . just 2 lbs. less than the XMax. It lacks ABS yet the brakes are excellent and although it doesn't offer LED headlamps the high beam is rather good and quite acceptable. Plus if the bulb burns out it's an economical fix. The XMax LED headlight is an expensive replacement item costing hundreds of dollars if it ever fails. Check out Gator's videos on the night ride . . ..
I still find that new Like 150i a temptation because it can be had for less than $3k and it's predecessor the Like 200i about $100 cheaper. If the seat on the Like 200i was better I would have bought one a long time ago. That hidden hump really turned away a lot of potential buyers IMHO. But you took care of that problem with a rebuild. Still runs great right? Any problem getting parts for it? Any problems with turn signal interference on sharp turns? Does it get to 70 MPH?
