Belt check
- sunshine
- Year: 2016 PCX
Belt check
Check my belt at 20000km good to go another 5k.
- 20190108_001440.jpg (91.65 KiB) Viewed 1547 times
grndslm
Re: Belt check
People say that the belt needs replacing at 5,000 to 10,000 miles or so for optimal efficiency.
I only have a general idea how the belt works... And since it's a V-belt connected to the smooth variation and clutch drivefaces, I wonder if the belt must be checked at the outer edges instead of the splines. . . .
- raito
- Color: matte silver
Re: Belt check
Maintenance schedule recommends inspecting every 8,000km and replacing every 24,000km. At 11,400km, I have not inspected mine yet..
- drive belt maintenance.png (149.36 KiB) Viewed 1460 times
Re: Belt check
My experience is a brand new belt will need a couple thousand miles to achieve optimal performance. I learned this by prematurely replacing a low mileage belt with a new one (both belts where identical cogged versions in this test). If anyone has suffered degrading performance and found a new belt to be the cure let me know otherwise the scheduled replacement recommendations by Honda might be more breakage prevention over maintaining performance. Hows the giddy-up with that belt?
