12 mm sockets and an extension are needed to remove the fill and the drain plugs.
Approximately .1 of a quart (100 ml) of gear fluid is needed. Honda owner's manual recommends 10W30 engine oil.
I recommend Synthetic 75W90 gear fluid.
https://youtu.be/nk5gLy2c8vQ
How to change final drive gear fluid 2018 PCX -long video
Inoplanetyanin
- Year: 2018
- Color: WHITE
Re: How to change final drive gear fluid 2018 PCX -long vide
The gear fluid on a 2018 bike laready needs changing! (should last years). If Honda say engine oil is good enough, nothing wrong in using that especially as many of us do so and have zero issues.
springer1
- Year: 2018
Thats what Honda says. But when I changed mine at 600m, there were metal specs visible all through it. When I changed it again at 1,500m for the heck of it, however, there were none.The gear fluid on a 2018 bike laready needs changing! (should last years).
Inoplanetyanin wrote:Honda owner's manual recommends 10W30 engine oil.
What do Honda know? Idiots.
Inoplanetyanin
- Year: 2018
- Color: WHITE
You can go ahead and use the thin engine oil but don't be surprised when you wear out your final drive prematurely. If you want to understand why I recommend the gear oil just search the internet.
PCX2016
- Year: 2016 Special
- Color: White Edition
I just changed my final drive today.. Here in the Kingdom we have this stuff.
Sent from my SM-G950U using Tapatalk
- ddd.jpg (63.23 KiB) Viewed 4167 times
American in Cambodia !!!
Honda spec engine oil, dealers often use it - never heard of any trouble using it.
