Progressive Mini Gauge Pump 60 PSI
Denny
Year: 2021
Post by Denny »
Just got this high quality aluminum hand pump for under $55 from revzilla. It says you can use it for adjusting air pressure on your aftermarket forks or shocks. I got stock suspension so I got this compact pump for my tires. It fits easily on the tire valve stem without any problems or need for angled fittings. It has a clear and accurate psi gauge, they sell four different pumps with gauges that read up to: 30, 60 (which I have), 100, 300 psi. It has a nifty adjust bleed off and has lets a very minimal amount of air out while disengaging the pump. I’m very pleased with this pump.
Re: Progressive Mini Gauge Pump 60 PSI
Good luck with that!
Nice to have onboard if you pick up a slow leak from a nail or something. It could be the ticket home you need when there's no gas station with a pump around for miles. :D
