Hello guys, new member here. I got the PCX 150, 2015 model.
Some few odd months ago the blinkers started going haywire.
The LEDs are working, that's a fact.
When I press the left blinker, it doesn't open, neither the speedometer light, neither the blinker itself.
The right blinker works, both speedometer and blinker.
When I open the hazards lights, neither one of the blinkers work (speedometer or blinkers).
Went to a repair shop, they fixed them (cost me only 30€), but told me that it might happen because they did something to the wires (like they aren't long enough, and they lengthen them, something like that).
Lo and behold it did happen again, after about a month (maybe less). Same thing again.
Talked to them (haven't went there with the scooter yet), and asked them about a more stable solution, and said that the whole wires must change (which is like 300€ + work, their quote).
One day as I went out, ALL of them started working again on their own, but after leaving, after a while (not a lot mind you) the same problem again.
Was wondering if this is a common issue with these models.
Thanks!
PCX 150 blinker problems
Re: PCX 150 blinker problems
There have been others on this forum who took the switch apart and cleaned the contacts with some contact spray, and everything worked again. You might try that first.
What switch are you saying? The blinker switch or the hazard switch? Because both dont work correctly
If you can take them apart, do both. If they are not sealed completely the contacts can get corrosion in them.
Hi, problem is in 6 pin or 20 pin LED control unit, in 6 pin is ground for HI, ground for left and right turn signal...
you must take the contact cleaner and use it to clean the pins...
I used it and problem is not...
it's only a week, but it still works...
Sorry, but I speak little English... google translator is my friend...
