indicators
wgry234
Year: 2013-14
indicators
Post by wgry234 »
hi all thinking of buying a 2016 pcx the pcx in question the indicators and hazards are not working easy fix or should i leave alone
Re: indicators
Could be a few things, failed relay, wrong bulbs, knackered switches or wiring.
Worst case it could need a big strip down to fix wiring.
Get the seller to fix it prior to sale.
If seller refuses to fix there's no shortage of other PCXs for sale.
wgry234
Year: 2013-14
Re: indicators
Post by wgry234 »
gn2 wrote:Could be a few things, failed relay, wrong bulbs, knackered switches or wiring.
thats true thanks for reply
easyrider
Color: blk
Re: indicators
Post by easyrider »
Turn signal relay.. Check all wiring connectors for looseness /corrosion. Its location is under the meter panel. Unplug and spray with electronic cleaner all connectors . Re connect and test.You can also jump the terminals, turn ign. on and see if it works. If not replace.
wgry234
Year: 2013-14
Re: indicators
Post by wgry234 »
easyrider wrote:Turn signal relay.. Check all wiring connectors for looseness /corrosion. Its location is under the meter panel. Unplug and spray with electronic cleaner all connectors . Re connect and test.You can also jump the terminals, turn ign. on and see if it works. If not replace.
thanks for reply
Re: indicators
GN2 is right, easiest thing to do is to get them to fix it or look at another.
As easy rider has said the likely issue (if non of the bulbs are working) is the relay. It's a quick fix.
I'd take the risk if I could knock down the price enough. No indicators, no MoT ;) ;)
wgry234
Year: 2013-14
Re: indicators
Post by wgry234 »
bought it indicators are fine centre stand siezed tried a couple of taps with a hammer broke lug off oil leak cracked the crankcase new engine on its way
Re: indicators
wgry234 wrote:bought it indicators are fine centre stand siezed tried a couple of taps with a hammer broke lug off oil leak cracked the crankcase new engine on its way
How do the English say, " DadGum!"
GeorgeSK
Year: 13PCX,15Forza
Color: Both Red
Re: indicators
Post by GeorgeSK »
Humph. On a 2016. I thought that little issue was fixed when they went to the ESP design in 2011 or 12.
Must have been really badly corroded. Sorry that you made yourself so much more work and expense.
wgry234
Year: 2013-14
Re: indicators
Post by wgry234 »
received engine today a 2018 pcx 125 with 1100 miles on all fitted and running sweet
Re: indicators
wgry234 wrote:received engine today a 2018 pcx 125 with 1100 miles on all fitted and running sweet
That was quick. :D
wgry234
Year: 2013-14
Re: indicators
Post by wgry234 »
no point in waiting needed doing managed to get a couple of bottle of touch up for the siena red will air brush it and see how it turns out
Re: indicators
Maybe you used the wrong type of hammer? :D
The centrestand arrangement is farcical, there's no provision for lubrication and it isn't even listed in the service schedule.
If riding in wet weather the stand pivot needs constant attention and the centre stand needs to be used frequently or it WILL seize.
