valve adjustment feeler gauges
- pcx888
- Color: pearl white
What the correct size of feeler gauges. .009 is exhaust and 0.004 is for intake. BUT if you read .009 feeler gauge is not .24 its .229 so im confused.
2011 White PCX
Aftermarket Thai Seat.
Rear NCY 1000 contra spring.
NCY Textured clutch bell.
- E. Foster Salsbury
- Year: 2015 NSS300A
- Office Minion
- Year: 2018
- Color: Dark Pearl Blue
Re: valve adjustment feeler gauges
Took me a minute. .009in is .229mm, but some of the posted specs say .24mm for the exhaust side.
I'm going to wildly guess that .24 is a common size for metric only sets and .229 isn't? I don't know if that's the answer, but a range of .008 -.010 converts to .20-.25 so you're probably fine either way and that's why you have a range that's all considered ok.
2018 Dark Pearl Blue PCX150
2014 Glowing Red Forza 300
- Year: 2018
Well done! The spec says + / - .001 is within tolerance anyway............ but a range of .008 -.010 converts to .20-.25 so you're probably fine either way and that's why you have a range that's all considered ok.
- pcx888
I used .010 rode over 150 miles. So it should be fine.
2011 White PCX
