in favor of lighted top cases!
You can see why I like this top case so well.
In low light situations it is great - but even in high sun it is quite visible to following cars. All the wrap-around LEDs double with braking, and adds a brake light above the chrome piece.
A Bestem 929 case, lights come installed, simple wiring, mounting kit included. Have had it on this scoot for five years. @ $125 direct from Bestem.
Sure, I wish it was a little smaller.
Last ride of this month.
Re: in favor of lighted top cases!
I love lighted top cases! My case did not come with a string of led lights like yours did. I ended up adding some lights as well as the kit that came with it, which stopped working a year later and I replaced with my own. Then I added an led string around the base plate, plus a double stack of 5 less below those, attached to the base plate as well. I also have a 'Knight Riderz' light above the license plate, and i replaced the red reflector with a lighted red reflector.
New brake lights.jpg (60.58 KiB) Viewed 633 times
