Stolen PCX125 Not Starting
				northernmunky
- Color: red
So as I've mentioned before, I have a PCX125 2013 model that was stolen and recovered. I've managed to solder back on the ignition barrel and replace all the damaged fairing. It powers on now, but when you try to start it, absolutely nothing happens. I can't seem to figure out the cause.
Things to note:
I've replaced the ignition power relay that sits next to the battery - no effect.
The winker/stop/horn 10amp fuse immediately blows when you turn the key.
The only other thing I can think of worth mentioning are that the thieves for some reason removed the bolt that holds on the left hand brake lever - I dont know why and I can't tell if theres any damage to it but does something need to be in place to complete the ignition sequence?
Also I also noticed that sometimes when trying to start it I can hear a subtle click near the engine but if you try again, its nothing but silence.
Unfortunately my knowledge of engines is limited, I've got it looking like a bike again but not much further in the way of getting it started!
Any ideas much appreciated!
						Things to note:
- d1ckyh
- Year: 2018
- Color: Blue
Re: Stolen PCX125 Not Starting
doesn't the handle have to be depressed for the engine to start? I always use the left so don't know if the right side will work. If fuses are blowing, I think it is a grounding issue...
									PCX - Peace Comes with eXcellence
				northernmunky
- Color: red
Thats right, left brake lever and then ignition switch on the right. For some reason they removed the bolt which I've now replaced but not starting.d1ckyh wrote:doesn't the handle have to be depressed for the engine to start? I always use the left so don't know if the right side will work. If fuses are blowing, I think it is a grounding issue...
Could it be as simple as putting your Side Stand up?
				northernmunky
- Color: red
Nope, not that either.WhiteNoise wrote:Could it be as simple as putting your Side Stand up?
You can also start the bike by using the right brake lever. We had this discussion a year or two ago and I went out to my bike and tried it on the right. It started right up. Try that and let us know. It is possible that the left one was damaged in some way.
				northernmunky
- Color: red
Tried that too, no joy.Mel46 wrote:You can also start the bike by using the right brake lever. We had this discussion a year or two ago and I went out to my bike and tried it on the right. It started right up. Try that and let us know. It is possible that the left one was damaged in some way.
I can see some metal contacts on the left brake lever which I'm assuming need to be in contact with what looks like a small metal plate on the lever itself in order to allow the starter button to work? (Im going from memory atm so apologies if I'm incorrect).
- JohnL
- Ozzie Old Fart
- Color: Dark Red
That's interesting, I tried it on my bike, no go on the right hand side. Maybe it's a regional thing or particular models?Mel46 wrote:You can also start the bike by using the right brake lever. We had this discussion a year or two ago and I went out to my bike and tried it on the right. It started right up. Try that and let us know. It is possible that the left one was damaged in some way.
				northernmunky
- Color: red
Right hand side didnt work for me either, but I had a closer look at the left and I've worked out how it works. So its effectively a kill switch, when you squeeze the brake lever, the (lets call it a kill button/ kill nipple?) is released presumably allowing the bike to start. So that looks likes its set up correctly but non starter.JohnL wrote:That's interesting, I tried it on my bike, no go on the right hand side. Maybe it's a regional thing or particular models?Mel46 wrote:You can also start the bike by using the right brake lever. We had this discussion a year or two ago and I went out to my bike and tried it on the right. It started right up. Try that and let us know. It is possible that the left one was damaged in some way.
- d1ckyh
- Year: 2018
- Color: Blue
Due to fuses blowing, I'd got out on a limb and say there is either a loose wire or one not connected properly which may or may not be causing the starting issue but all the same should be checked. Since it is tied to the left hand side, I would remove the switch and see if all is intact. The fact they removed the bolt may be an indication they did something else????
Battery is OK?
On my 2013 model I believe the wiring diagram shows both sides connected together. It is possible that newer ones don't work that way. I believe that the wiring diagram also shows the circuit having a fuse on the main panel. If it is blowing that fuse then there is a wire loose somewhere that is shorting out the start circuit. Thieves have studied what they need to do to get the scooters running as quickly as possible, so they would probably connect wires directly to the battery.
It may require you to start removing panels and follow the wires. It isn't an easy task, but at least the wires have unique colors. Pull out you wiring diagram and start following wires.
Hi I'm new to this forum. I bought a new pcx which doesn't have warrenty in my country.. pcx 160 2022.
When I presss the self start button the main fuse is blowing and it's doesn't start.. my mechanic spen 3 days now checking the ecu and wire harness and could find the fault.. can you help me what to do..
All lights horn efi and everything is working it i press the self start button the main fuse is blowing
