hi guys, how often we need to put/refill water in the radiator.
what water best to use; normal water will do or can we use the engine coolant (for cars).
thanks heaps.
Radiator
Radiator
It's a sealed system so it shouldn't lose much if anything. If it does need a topup then use a 50/50 water, coolant mix. If it continuously needs a top up then best to get it checked for leaks.
Re: Radiator
It is essential that you use the correct coolant.
The wrong stuff can trash the engine.
As with all servicing, do it when the schedule calls for it and not before.
Re: Radiator
You can check the coolant level easily enough. Its just under the seat
- EddieC
Re: Radiator
The maintenance schedule calls for the coolant to be replaced every 2 years.
Re: Radiator
thanks everyone.
thats very helpful.
ehdlhou
thats very helpful.
ehdlhou
