125/150 parts compatibility and interchageability
cessna151
Post by cessna151 »
When i first bought my PCX150 i had no idea how it was different than the 125 other than the engine and many distributors still don't list parts for the 150. With some help on the other forum i have organized a short list of parts according to whether or not they can be used on both the 125 and the 150.
I will continue to add to this list as reports come in.
INTERCHANGEABLE
Variator (However, stock variators may vary slightly between the two)
Seat
Windshield
Wheels/tires
NOT INTERCHANGEABLE
Air filter/air cover
Radiator/radiator cover
Exhaust/header
cessna151
Re: 125/150 parts compatibility and interchageability
Post by cessna151 »
Can anyone verify that all the plastic body work is the same on both?
Mitch Detailed
Post by Mitch Detailed »
Some plastics are, some aren't. The physical mounting points are the difference. Look up the frame between the 125/150 and you'll see they completely redesigned the frame system
cessna151 wrote:Can anyone verify that all the plastic body work is the same on both?
Apart from the fuel flap panels it does seem to be the same
cessna151
Post by cessna151 »
If that's the case i think it would be a good idea to sort out which ones are or aren't.
On a side note, why can't i edit my OP?
Mitch Detailed wrote:Some plastics are, some aren't. The physical mounting points are the difference. Look up the frame between the 125/150 and you'll see they completely redesigned the frame system
So which are and which aren't?
Mitch Detailed
I don't know off the top of my head. The midsection is where it gets tricky. The bike is .6 inches longer wheelbase. And there's a spark plug access panel not present on the 150s.
There's no spark plug panel on the 150s? I've got an ESP 125 and just assumed it was a sleeved down 150, but its got the sparkplug access hatch
Mitch Detailed
Look at illustrated parts diagrams on sites, you'll see ;)
Life is too short, I'll take your word for it :)
cessna151
Post by cessna151 »
I have the 150 service manual. Perhaps if somebody has a 125 service manual we could compare pictures to determine which are different.
cessna151 wrote:On a side note, why can't i edit my OP?
Forum rule -- it prevents bait and switch, and keeps everyone honest.
Send me a PM or reply if you want the OP updated, and I'd gladly update it for you. :)
