Hole in plastic next to ignition
Posted: Sun Feb 11, 2018 6:09 am
by d1ckyh
So I got my new 2018 PCX yesterday and going over it, I found a small rectangular hole in the plastic, just right of the ignition panel. Behind it is some kind of white cylindrical object. So my questions are; 1- is it supposed to be there? 2- what is behind it (the white thing) and 3- can it and what covers it up?
I've been admiring the workmanship and build of the scooter and it seems odd that there would be a hole there.
Thanks for any input!
On a second note. my tool kit that came wit the scooter only contains a wire cable thingy with loops on each end and a black plastic cover. Any clue what this is? I have my own tools so the lack of a complete honda kit was not an issue, just can't figure out what this thing is...
Re: Hole in plastic next to ignition
Posted: Sun Feb 11, 2018 7:36 am
by springer1
That’s all mine had too. Put it thru the metal loop on your helmet and then double it over and put both ends over the hook inside the seat ... close the seat and it’s a helmet lock cable. Some people use it for a tow cable too LoL.
Congrats on your pcx - you’ll be amazed what a 150 scoot can do. And welcome to the forum !
Posted: Sun Feb 11, 2018 7:50 am
The hole is to check the brake fluid level. Shine a torch in and all will become clear :D
Posted: Sun Feb 11, 2018 10:53 am
by d1ckyh
Ah, it all makes sense. I initially thought the hole was for a non usa add-on and it was missing a cover. Thanks! I was about to take it back to the dealer and tell them to put a cover on it.
Posted: Sun Feb 11, 2018 4:22 pm
Crazy right? I asked the very same question when I got my '15. What's that "porthole" all about? Once I found out, I then wondered IF any fluid was in it :roll: I needed to shed some light in there. The fluid level turned out to be fine after I realized it was Clear in color! Lol
This from my 2015 owners manual: (sorry, it's a rainy dismal day here)
About the tools? Got the same flimsy snap pouch with a helmet strap inside it. That's All Folks!
