w5w cree led bulb
Posted: Tue Dec 04, 2012 12:50 pm
by trigg123
as per the title i found these on flea bay and bought some.......very good indeed and are small enough to fit in the pcx side light bulb holes.....quite expensive but very bright.....
http://www.ebay.co.uk/itm/350604461211? ... 1497.l2649
Re: w5w cree led bulb
Posted: Tue Dec 04, 2012 7:50 pm
by Taz
Have you installed them? What do you need to do to install them? Any photos? Any improvement over stock? Details please!
Posted: Wed Dec 05, 2012 1:15 pm
by trigg123
simply swap them over mate, no pics but very good and a massive improvement over stock
Posted: Thu Dec 06, 2012 9:20 am
by Cracksta
Easy to do, my only problem is the headlight color wont match so I'm still using the originals.
Posted: Mon Dec 10, 2012 5:58 am
by Trawlerman
How did you get those to fit? I bought some the same with the metal shrouds and they wouldn't fit through the opening?
I eventually bought another set of LEDs with the same profile as the original filament bulbs which fitted 100%
Posted: Mon Dec 10, 2012 1:12 pm
by trigg123
hi mate
they just fit as a direct replacement and no mod required,that specific link above is for a 12mm wide body led and that is what you get,i bought some previously and are much wider and didnt fit,
hope that helps
regards Trigg
Posted: Fri Dec 14, 2012 11:31 pm
by Trawlerman
ah right. thats my problem, my Cree bulbs are 15mm wide hence why they don't fit
