as per the title i found these on flea bay and bought some.......very good indeed and are small enough to fit in the pcx side light bulb holes.....quite expensive but very bright.....
http://www.ebay.co.uk/itm/350604461211? ... 1497.l2649
w5w cree led bulb
w5w cree led bulb
Re: w5w cree led bulb
Have you installed them? What do you need to do to install them? Any photos? Any improvement over stock? Details please!
simply swap them over mate, no pics but very good and a massive improvement over stock
Easy to do, my only problem is the headlight color wont match so I'm still using the originals.
Trawlerman
How did you get those to fit? I bought some the same with the metal shrouds and they wouldn't fit through the opening?
I eventually bought another set of LEDs with the same profile as the original filament bulbs which fitted 100%
hi mate
they just fit as a direct replacement and no mod required,that specific link above is for a 12mm wide body led and that is what you get,i bought some previously and are much wider and didnt fit,
hope that helps
regards Trigg
hope that helps
regards Trigg
Trawlerman
ah right. thats my problem, my Cree bulbs are 15mm wide hence why they don't fit
