Over 6,000 miles. What do ya think? Still look good?
Finally pulled the plug!
- spark
- image.jpeg (114.54 KiB) Viewed 5043 times
- WI_Hedgehog
- Powered by angry squirrels
- Color: PearlDrkAshBlue
Re: Finally pulled the plug!
You could clean and gap it, but why? For $1.29 screw a new one in. Looks great though.
Here's your plug if you shop Amazon... I wish it was 1.29
where did you see that price?
https://www.amazon.com/gp/product/B001R ... UTF8&psc=1
- WI_Hedgehog
Fleet Farm, Tractor Supply, probably AutoZone/O'Rieley/etc. It's not a special "iridium tipped" plug, just a standard spark plug.homie wrote:Here's your plug if you shop Amazon... I wish it was 1.29where did you see that price?
Shoulders are worn and rounded on the center electrode - not square & sharp as is found on a new plug.
Scooter runs, though - so no need to change.
Use the same maint. practices on the engine oil. Keep the orig. oil topped up, never change it, and she'll likely run longer than you will own it. My 18 yr old Sear's mower outlasted me this way.
fish wrote:Shoulders are worn and rounded on the center electrode - not square & sharp as is found on a new plug.
True.
Speaking of lawn mowers, I am glad that Honda thought enough about changing oil on the PCX that they actually put a bottom drain plug in. On my Honda lawn mower they have a recommended schedule for changing the oil, but they don't provide a drain hole in order to drain It! That means that I have to turn the lawn mower upside down to drain the oil. Boo....
- JohnL
- Ozzie Old Fart
- Color: Dark Red
My Honda mower (lightweight model) is over 16 years old and has had the oil changed about three times in it's life. No blue smoke, still starts second pull and never lets me (or my wife) down.
Actually my wife has graduated to a Ryobi 36v battery mower, it's amazingly good on flat ground, but the Honda is best for all round cutting.
RPM68
Mel46 wrote:Speaking of lawn mowers, I am glad that Honda thought enough about changing oil on the PCX that they actually put a bottom drain plug in. On my Honda lawn mower they have a recommended schedule for changing the oil, but they don't provide a drain hole in order to drain It! That means that I have to turn the lawn mower upside down to drain the oil. Boo....
I have a Honda mower as well. No drain plug! That's where the vacuum/suction pump works well. No dumping the mower over and letting the oil run everywhere. It's a much tidier method.
Bob
Living the Dream!
2016 PCX150 in Matte Silver
JohnL wrote:My Honda mower (lightweight model) is over 16 years old and has had the oil changed about three times in it's life. No blue smoke, still starts second pull and never lets me (or my wife) down.![]()
Birthday present?
springer1
- Year: 2018
My son must have a different model, his is not located on the lower side of the engine where mots are, rather underneath where the blade is ... it gets covered with a layer of grass & stuff, but that's where his is.Mel46 wrote:Speaking of lawn mowers, I am glad that Honda thought enough about changing oil on the PCX that they actually put a bottom drain plug in. On my Honda lawn mower they have a recommended schedule for changing the oil, but they don't provide a drain hole in order to drain It! That means that I have to turn the lawn mower upside down to drain the oil. Boo....
Red Green had an F-150 that had a seized drain plug....so he had to do the same as with your mower.Mel46 wrote:Speaking of lawn mowers, I am glad that Honda thought enough about changing oil on the PCX that they actually put a bottom drain plug in. On my Honda lawn mower they have a recommended schedule for changing the oil, but they don't provide a drain hole in order to drain It! That means that I have to turn the lawn mower upside down to drain the oil. Boo....
No, he's not stupid. He didn't turn the truck over - instead he pried the engine out, with some difficulty - not having any tools save for a spud bar and a sledge. Poured the oil into a bucket, to use in his wife's car.
A fellow just needs to think things through....
- PCX150Rider
Couldn't help but laugh. . .sorry. . ..Red Green had an F-150 that had a seized drain plug....so he had to do the same as with your mower.
- JohnL
- Ozzie Old Fart
- Color: Dark Red
Yes, but she paid for ityou you wrote:JohnL wrote:My Honda mower (lightweight model) is over 16 years old and has had the oil changed about three times in it's life. No blue smoke, still starts second pull and never lets me (or my wife) down.![]()
Birthday present?
JohnL wrote:Yes, but she paid for ityou you wrote:JohnL wrote:My Honda mower (lightweight model) is over 16 years old and has had the oil changed about three times in it's life. No blue smoke, still starts second pull and never lets me (or my wife) down.![]()
Birthday present?![]()
Full marks.
