Winter storage
- Sandymay
- Scooter Sandy
- Color: Bronze
Winter storage
I live in Ontario and unfortunately can’t ride my Forza from November til probably April, due to ice and snow.
My question is what do you do to winterize your ride? I’ve got heated storage arranged for mine. Should I add fuel stabilizer to the gas tank? The battery will be on a trickle charger. Any other good ideas?
Thanks so much,
Sandy
Thanks so much,
Sandy
TheMaverick
Re: Winter storage
Hi Sandy,Sandymay wrote:I live in Ontario and unfortunately can’t ride my Forza from November til probably April, due to ice and snow.
Thanks so much,
Sandy
Our benevolent overload posted on this very topic some time ago:
http://hondapcx.org/viewtopic.php?f=15&t=14
We've had other discussions more recently, but I can't find them just at the moment - off memory the advice given in the thread above pretty much summed it up though.
Re: Winter storage
In addition I like to lessen the air pressure in the tires about 10 pounds and plug in an electronic rodent deterrent device close by. Some of you guys and your horror stories of critters liking the cowlings and fairings
TheMaverick
Re: Winter storage
* OverlordTheMaverick wrote:Our benevolent overload posted on this very topic some time ago:
(wish posts could still be edited for a slightly longer period!)
davenowherejones
Re: Winter storage
I start mine up every once in a while on warmer days and let it run until it is up to temperature plus another 5 minutes.
- Year: 26 adv 160
Re: Winter storage
Once your bike goes to sleep, leave it alone don’t start it until you're ready to take it out in the spring. When you start a bike and let it idle for a few minutes you’re adding more condensation to the oil and not doing it any good. If you can take it out and run it for 20 minutes once a month that’s different. But don’t start and idle it. This has been gospel on all internal combustion engines going into storage.
- Sandymay
- Scooter Sandy
- Color: Bronze
Re: Winter storage
Thanks everyone!
Re: Winter storage
Agreed... we don't fire them up until spring unless you plan an oil change at the start of the season.Jge64 wrote:Once your bike goes to sleep, leave it alone don’t start it you’re adding condensation to the oil
Re: Winter storage
Interesting. I be curious, why let air "out" of tires during winter's rest homie? I keep mine @ 29/F & 33/R. My bicycles are kept at spec too.
Haha! I used battery operated rodent deterrent stakes in Florida. Drove them in the ground along perimeter of my property and in garden beds to ward off those damn gopher's! Did they work? Only if they ran straight into them
P.I T.Buttskees!!!
I keep an electric heater set up in the garage during the cold months.
You might consider plugging the hole in your exhaust's tail pipe, mice can squeeze in/get in just about anywhere.
Check out a product called Damp-Rid (Amazon, Home Depot, etc) for controlling moisture. Can buy in small pales, pouches, or hanging bags. I have the pail version set up in garage all the time. They work!!
Ok, I'm done.
What else ya got peeps?
Here's a question...Do you cover, or not cover your "precious," during storage?
Ok, I'm done.
TheMaverick
Re: Winter storage
Storage? What is this unfamiliar word that you use?WhiteNoise wrote:Here's a question...Do you cover, or not cover your "precious," during storage?
Mister Paul
Re: Winter storage
I'd roll it around a bit occasionally. It's not good for tyres to be sitting with one section in contact with the ground for long periods of time.
TheMaverick
Re: Winter storage
I think it's almost a given that it should be put on the center stand.Mister Paul wrote:I'd roll it around a bit occasionally. It's not good for tyres to be sitting with one section in contact with the ground for long periods of time.
Mister Paul
Re: Winter storage
Yeah, but that still leaves the front.TheMaverick wrote:I think it's almost a given that it should be put on the center stand.Mister Paul wrote:I'd roll it around a bit occasionally. It's not good for tyres to be sitting with one section in contact with the ground for long periods of time.
TheMaverick
Re: Winter storage
Only a tiny fraction of the original weight though - the pivot point moves forward dramatically when on the center stand.Mister Paul wrote:Yeah, but that still leaves the front.TheMaverick wrote:I think it's almost a given that it should be put on the center stand.Mister Paul wrote:I'd roll it around a bit occasionally. It's not good for tyres to be sitting with one section in contact with the ground for long periods of time.
davenowherejones
Re: Winter storage
I have a little dumb solar cell charger I put on the battery which is kind of silly because the sun hardly ever gets above the mountains in Hope when it is too icy to ride. It seems to work anyway.
Re: Winter storage
davenowherejones wrote:I have a little dumb solar cell charger I put on the battery which is kind of silly because the sun hardly ever gets above the mountains in Hope when it is too icy to ride. It seems to work anyway.
At least you've got hope.
Re: Winter storage
Hi Mr. Paul...
I agree, no need to develope flat spots on tires
Leave bike up on center stand - rear tire is off the floor, (that's soo cool!) If you are physically capable, place yer hands on the front wheel and carefully spin it till you change it's resting position. No need to roll around
Yeh!
Re: Winter storage
Hardy Hahaha - HaH!TheMaverick wrote:Storage? What is this unfamiliar word that you use?WhiteNoise wrote:Here's a question...Do you cover, or not cover your "precious," during storage?
- djbass
- Year: PCX150, 2015
Re: Winter storage
In the winter I put the PCX in the garage on the center stand and cover with a cover from dust, the battery is not removed.
Re: Winter storage
djbass wrote:In the winter I put the PCX in the garage on the center stand and cover with a cover from dust, the battery is not removed.
Same just without the cover, that would just attract my cats.
It's just a scooter.
