Forza How-to
Maintenance, guides, and walkthroughs for your Forza. Please do not post questions about repairing or fixing your bike here.
Forza How-to
As requested, here's the Forza how-to section. I only have a PCX, so I leave the content creation for this forum up to you guys and gals. :D
johnparham
Year: 2021
Color: Blue
Re: Forza How-to: install front and rear cameras - help please?
Post by johnparham »
Hi All,
I've invested in and installed a 7" Android Auto display, using the screw hole in the left brake lever 'mirror mount' and an extension bar.
This device came with front and rear cameras. I've successfully installed the front, but I'm stuck on the rear....
Has anyone fitted a rear cemera to NSS300 or 350? Best place seems to be on the black plastic moulding just underneath the brake light, but I can't see how to get at the back of that plastic piece... I took the under seat luggage box out and hoped I could get access, but that didn't help...
Has anyone removed the rear brake light cluster? How do you do that?
Lastly, I assume the best place for the cable to run is similar to the front and up through the steering tube recess, but how do I get the cable from the battery box area up through the fuel filler cover and other covers to the front tube?
Would be great to hear from someone that's done it!
Thanks in advance
