Hand grips compatibility
kar120c
Year: 2015 Forza 300
Post by kar120c »
I wish to upgrade to Rizoma Sport "universal" grips. Anyone knows what is the Forza handbar diameter ?
montliz44
Year: 2013,2014
Color: red+redder
Re: Hand grips compatibility
Post by montliz44 »
They take the 3/4 inch grips if you order from a US supplier. I'm not how Rizoma sells them in Italy, but almost all European and Asian bikes use that size. The other size is 1 inch, which is for Harley-Davidsons.
Biltwell in the US makes really nice grips too.https://www.revzilla.com/biltwell?gclid ... Mc4irBoCM2
Johnny
davenowherejones
Post by davenowherejones »
kar120c wrote:I wish to upgrade to Rizoma Sport "universal" grips. Anyone knows what is the Forza handbar diameter ?
A lot of bikes use a 7/8 inch diameter bar (22 mm). I will measure mine later.
davenowherejones
They are measured at 7/8 or 22 mm. No idea where you got 3/4 from?
dergav
Color: grey
Post by dergav »
they are 7/8 ins. I think thats a standard size for handlebars. You will find when you remove the Forza grips that there are ridges on the remaining bar which I needed to file off before being able to fit my Datatool heated grips. No big deal but not expected and a bit of a faff.
montliz44
Year: 2013,2014
Color: red+redder
Post by montliz44 »
OOOPs my bad -- I meant to say 7/8 --- Dagnabbit!
Johnny
kar120c
Post by kar120c »
Thanks. Confirmed 7/8 22mm?
montliz44
Year: 2013,2014
Color: red+redder
Post by montliz44 »
Confirmed. Sorry about the confusion. When you get them you'll notice that one has a slightly larger diameter than the other. The larger one goes on the twistgrip side, your right-hand side.
Johnny
davenowherejones
I tried to change grips on my previous DR650. It was very difficult to get the old factory grips off. I used a knife and a grinder which made a huge mess.
Getting the new grips on was not pretty also. They were tight and the glue went everywhere. The DR650 had bar ends so I had to cut off the end of the new grips. It was not pretty. The replacement soft grips did not last very long. I will stick with my factory grips for now.
Your results may be better than my mess.
dergav
Color: grey
Post by dergav »
grips will all of course be different...but I didnt need to use any glue with the Datatool...even although was provided...just worked them on with effort and some WD40 and they havent moved..didnt notice any size difference but there again because heated grips it was obvious which grip went on which side.The Datatool grips are fairly big/wide but that suits me as I dont like small narrow grips.
As I said the biggest unexpected "faff" was filing of the ridges once old grips cut off.
best of luck fitting.
dergav wrote:grips will all of course be different...but I didnt need to use any glue with the Datatool...even although was provided...just worked them on with effort and some WD40 and they havent moved..didnt notice any size difference but there again because heated grips it was obvious which grip went on which side.The Datatool grips are fairly big/wide but that suits me as I dont like small narrow grips.
Same here. I just used a sharp knife for the ridhes. Faff is right. That was about it
