OBD port?
				pappasmurf
- Color: Steel Grey
OBD port?
My 2017 125cc PCX needed an oil change.
This was done, yet there is still the message 'Oil Change' on the dash.
How is this cleared?
Is there a procedure?
Is there an OBD tool or similar available for the PCX?
I've seen many OBD tools online, but not sure which one works on the PCX.
Also read somewhere that the PCX doesn't have an OBD port.
Can anyone clarify?
Thanks.
Can anyone clarify?
Thanks.
Re: OBD port?
Not 100 percent certain because I don't have this feature but I seen it on youtube with another Honda scooter.
Warning to all the rest of us without the new oil change light... don't do this It will disable the limiter and you will go 100 mph.
With ignition off push & hold the clock button.
turn on the ignition, release button.
 It will disable the limiter and you will go 100 mph.With ignition off push & hold the clock button.
Re: OBD port?
Oh and let us know if this works so admin can change the title to something searchable... thanks
				TheMaverick
Re: OBD port?
I don't have a clock on mine, so I held down the trip reset button instead, but only get 95 MPHhomie wrote:Not 100 percent certain because I don't have this feature but I seen it on youtube with another Honda scooter.
Warning to all the rest of us without the new oil change light... don't do thisIt will disable the limiter and you will go 100 mph.
#SoDisappointed!
Re: OBD port?
You are right, no obd port which is a shame.
						- easyrider
- Color: blk
Re: OBD port?
Optional way..Install these ports.
https://drive.google.com/file/d/0B4Qx_9 ... sp=sharing
				izani
Re: OBD port?
Do google for HiDS (Honda Injection Diagnostic System) by Starnics, from Indonesia. Used by Honda dealer there.
Re: OBD port?
easyrider wrote:Optional way..Install these ports.
But they arent ECU reader ports...?
- easyrider
- Color: blk
Re: OBD port?
Oops..my mistake...OBD port could be a bit more challenging but not impossible..I don't know why I was thinking USB ???
				pappasmurf
- Color: Steel Grey
Re: OBD port?
Just tried that.homie wrote:Not 100 percent certain because I don't have this feature but I seen it on youtube with another Honda scooter.
Didn't do anything.
Still says 'Oil Change'.
Re: OBD port?
OK try this one, with ignition off press and HOLD RESET button while turning the ignition switch to the ON position, and keep holding the RESET button for more than 3 seconds. This is how the Forza owners do it maybe it's the same procedure on the new PCX.pappasmurf wrote:Just tried that.homie wrote:Not 100 percent certain because I don't have this feature but I seen it on youtube with another Honda scooter.
Didn't do anything.
