Refitting the rear wheel
Posted: Sun Jul 30, 2017 4:06 pm
This might help someone, you never know.
Just changed the rear tyre and sprayed the "swinging arm bracket. Had a devil of a job getting the wheel off and on again. Damaged the brake shoes. Brake was completely backed off.
New shoes were the same until I took the sharp edge off the shoe material so they could have a lead into the drum.
Easy peasy after that.
Re: Refitting the rear wheel
Posted: Sun Jul 30, 2017 5:59 pm
by homie
I'm up for the swing arm soon, just finished a chin with the coating.
Posted: Mon Jul 31, 2017 9:28 am
by montliz44
you you wrote:This might help someone, you never know.
Thanks for the tip, you you. Just like removing and replacing the front caliper assemblies on your BCR. A little file action on the pads and the calipers slip right on and off. Ezee is good.
Johnny
Posted: Mon Jul 31, 2017 9:34 am
montliz44 wrote:you you wrote:This might help someone, you never know.
Johnny
Yes. Just didnt think of it with the originals. Must have been a small lip. Last time I changed brake shoes was the early 80s
Posted: Tue Aug 01, 2017 7:25 am
by easyrider
You mentioned that you had a bugger of a time removing the rear wheel.I take it you mean the brake shoes was engaged with the drum.That is not a normal situation if you properly backed off the adjustment rod.Something amiss with the adjustment,wrong size shoes,or other abnormality.There should be no need to chamfer the leading edge to put the wheel on.You may be dragging.You should re check the installation and especially the adjustment mechanism and or the anchoring studs.
Posted: Tue Aug 01, 2017 10:28 am
by Smaug
Interesting. Mine came off easily, as long as I pulled it straight off. Went back on easily too, as long as I had it lined up and put it straight on.
All I had to do was loosen the rear fender bolts and tie the rear shock up to the turn signal stalk, so it wasn't in the way.
Just a reference point.
Posted: Tue Aug 01, 2017 12:52 pm
Smaug wrote:Interesting. Mine came off easily, as long as I pulled it straight off. Went back on easily too, as long as I had it lined up and put it straight on.
Mine was a complete g1t. I presumed it was the little bit of corrosion on the splines and shaft as the swingarm took some persuasion too.
Glad I did it just to get some grease in there.
