Bending exhaust?
Posted: Mon Jul 24, 2017 9:18 am
by Smaug
I just realized after changing the tires that the muffler is solidly bolted to the swingarm. How can it bend with every bump without breaking prematurely? Seems like kind of a bad/cheap design...
Re: Bending exhaust?
Posted: Mon Jul 24, 2017 9:23 am
by homie
The engine the header is bolted to is on the swing with every bump in the road, not a traditional swing arm on scooters... follow the engine mount bolts and you will see that (bracket) is not a swingarm
Posted: Mon Jul 24, 2017 9:31 am
Engine, wheel and exhausts are all one unit. That's the principal of most normal scooters. Excellent packaging but high unsprung weight.
Posted: Mon Jul 24, 2017 9:32 am
by homie
you you wrote:Engine, wheel and exhausts are all one unit. That's the principal of most normal scooters. Excellent packaging but high unsprung weight.
Youyou I think I'm going to paint my (bracket) too.
