Is it ok to use injector cleaner and if so, how often.
knoll
Color: Pearl Blue
Post by knoll »
I heard it's a good idea to use injector cleaner on my BMS Prestige 150 scooter on every fueling. Is it also a good ideal for the same on my 2018 Honda PCX 150?
Thanks for any comments.
easyrider
Color: blk
Re: Is it ok to use injector cleaner and if so, how often.
Post by easyrider »
Not necessary..
easyrider wrote:Not necessary..
X2
montliz44
Year: 2013,2014
Color: red+redder
Post by montliz44 »
If you live in the US you can buy Chevron or Texaco (same fuel marketed under two different brand names) gasoline. Their petrol contains a small amount of Techron, which is a cleaner/additive.
Otherwise put me down with Easyrider and You You : X3
Johnny
Smaug
Year: 2013 PCX150
Post by Smaug »
It's a good idea to use Techron injector cleaner annually, per instructions. (Unless you have some reason to suspect dirty injectors)
Mixing it down to the 1.3 gallon level is going to be a challenge though...
-Jeremy
knoll
Color: Pearl Blue
Post by knoll »
Thanks for all the comments. They were very helpful.
you two are really going to go with big face avatars... OK i'm in 8)
Any Top Tier gas station has all the additives and cleaners any Mercedes, BMW, Jeep, R. Royce, scooter or Ferrari needs already blended in the fuel.
No longer need sea foam, techron, dry gas, etc., except for placebo effect on the owner.
Want better performance for a few years...slip in a new $7 Iridium NGK or Denso spark plug.
Smaug
Year: 2013 PCX150
Post by Smaug »
fish wrote:Any Top Tier gas station has all the additives and cleaners any Mercedes, BMW, Jeep, R. Royce, scooter or Ferrari needs already blended in the fuel.
If I was always able to fill up with top tier gas, I'd probably agree with you. But with a limited range, sometimes, we have to get gas where/when it is available.
-Jeremy
