wish my pcx was 5 mph faster on hills
eggman
she drops to 50 mph on hills i want it to do 55
- lillypinkjenny
Re: wish my pcx was 5 mph faster on hills
I have this same issue with every small bike I ride for a while.eggman wrote:she drops to 50 mph on hills i want it to do 55
I get to thinking, "If only it did a extra few mph here ... or there."
I'm sure it's just a mental thing because once I get over it I realise that it is what it is.
It's finding that inner peace between you and the bike.
It works for me, anyhow. xxx
u33db
55 is achievable unless you are on an EXTREMELY steep incline....you will need to mess with rollers at a minimum though.
Remember it is what it is; if you live somewhere very hilly and have issues keeping up with traffic you probably need a bigger/more powerful bike.
Malossi 10.5g rollers
Malossi yellow clutch springs
HJC wind screen
HJC wind screen
eggman
ty u both.
I thought you were getting rid of your pcx??
If you are keeping it and want more speed, here is what you need:
1. NCY variator AND drive face
2. 13 gram rollers
3. New belt IF you have more than 3,000 miles on it.
These should give you another 10 mph.
2. 13 gram rollers
Mel is right eggman but know the cost to get this done.
https://www.corsportusa.com/i-18174-201 ... ulley.html 56.00
https://www.corsportusa.com/i-18182-201 ... -face.html 29.00
https://www.corsportusa.com/i-18176-201 ... s-13g.html 25.00
110.00 + new belt, the good news is you can do the install yourself because you are our newest CVT mechanic
- Smaug
- Year: 2013 PCX150
This is an issue with every bike under 1000cc.
With a 50, acceleration is slow, even if the top speed will let you (eventually) keep up in town.
With a 125-150, it can't keep up on hills outside of town
With a 400, it's breathing hard to keep up with traffic going 75-80.
With a 600 twin.... well OK, this only struggles on big hills where you want to go 75+
I had a Kawasaki Concours (1000cc, 4 cylinder) and when my wife and I were both on it, it was all I could do to beat a V6 minivan off the line. Traded up to a Yamaha FJR1300 ABS and found bliss. ....but it was roasting me at any speed less than 55 mph in the summer. Only got 45 mpg too.
There's always SOMETHING. You've just got to find your happy medium.
-Jeremy
eggman
i was going to sell it so i dint need to fux it but i replaced bearing... clutches...belt. plug... and airfilterMel46 wrote:I thought you were getting rid of your pcx??
2. 13 gram rollers
eggman
not badhomie wrote:Mel is right eggman but know the cost to get this done.
eggman
very trueSmaug wrote:This is an issue with every bike under 1000cc.
I wish my pcx was 500 mph faster on hills. Best to have a little in reserve.
A great deal considering the performance increases and you already have a new belt. Don't wonder off the 13 gram rollers as we have tested this NCY kit in here extensively with that combination of roller weight and it WILL please you tremendously. I would expect you to hit 78 mph on a slight down grade, don't know how it will do on the hill you are climbing. A good winter project for you eggman.eggman wrote:not badhomie wrote:Mel is right eggman but know the cost to get this done.
eggman
coolhomie wrote:A great deal considering the performance increases and you already have a new belt. Don't wonder off the 13 gram rollers as we have tested this NCY kit in here extensively with that combination of roller weight and it WILL please you tremendously. I would expect you to hit 78 mph on a slight down grade, don't know how it will do on the hill you are climbing. A good winter project for you eggman.eggman wrote:not badhomie wrote:Mel is right eggman but know the cost to get this done.
78 mph? I might have to get one.
- PCX150Rider
I often wonder how much better my PCX would perform if I returned to my High School weight.
Can't help you there. No kit will help a pot belly. :-/
- PCX150Rider
That's for sure!Can't help you there. No kit will help a pot belly. :-/
megalodon
- Color: pearl blue
i'm 85 kg 1.78 cm and my pcx doing pretty well 90 kmh 55 mph on long hill climbs. i don't know your situation looks not normal
- Smaug
- Year: 2013 PCX150
megalodon wrote:i'm 85 kg 1.78 cm and my pcx doing pretty well 90 kmh 55 mph on long hill climbs. i don't know your situation looks not normal
-Jeremy
- alx123
- Bangkok Rider
- Color: Fast White
interesting. but will this affect warranty?Mel46 wrote:I thought you were getting rid of your pcx??
2. 13 gram rollers
considering my weight (65 kgs), I can top my stock pcx 2016 a little around 71mph. wonder if how much will be the added top end if I install this set up.
Since top end will improve, will my acceleration suffer? a big deal since I'm always riding with a pillion.
Thanks.
