How do I unlock seat in case of a dead battery
ozzy7007
Post by ozzy7007 »
If the battery goes dead, how do I unlock the seat to charge the battery. The gas cover is on a cable , however the seat release is on an electronic release switch, I guess if I had a 12V outlet in the little compartment in the left front, I could put a charger in it, this may be a good reason to install one of them. Any comments welcome.. Ozzy
Re: How do I unlock seat in case of a dead battery
ozzy7007 wrote:If the battery goes dead, how do I unlock the seat to charge the battery. The gas cover is on a cable , however the seat release is on an electronic release switch, I guess if I had a 12V outlet in the little compartment in the left front, I could put a charger in it, this may be a good reason to install one of them. Any comments welcome.. Ozzy
chill...
The fuel/seat rocker switch has two bowden cables connected to it, one for the fuel cover and the other for the seat.
Taz
Post by Taz »
I think what they are trying to tell you is its mechanical, not electrical so they can be opened when battery is flat.
Taz hit the nail on the head... The latch to release the seat is mechanical, it'll work even if no battery is in the bike.
Tokkyu40
Year: 2020
Post by Tokkyu40 »
I think Asian bikes use a keyless fob instead of a key, so if your battery's dead you need a tool that goes in the slot beside the rocker to open the bike mechanically.
I'd like to get one just in case.
Here's a video of the technique. Apparently the tool is a standard part of the tool kit in the Philippines.
https://www.youtube.com/watch?v=vk-pGegMVkA
