Possibly to add DC 12V "cigarette lighter" socket
grndslm
Post by grndslm »
So my 2013 model doesn't have a cigarette lighter, so I can't just pop my phone charger in there for emergencies. This post got me wondering if there's any easier way of rigging my scooter up with phone charging capabilities...
Mel46 wrote:If you don't want to go through the trouble of swapping it out, if you use a Battery Tender and have the permanent wires attached to your battery, you can purchase a USB adapter that plugs into the end of it and feed a cable through the seat hinge.
https://www.amazon.com/s/ref=nb_sb_ss_i ... 2ZVSIU2XA4
I'm assuming this is one of my only options for adding a 12V socket to my 2013 model? It will probly be best to have it rigged under the seat for waterproofing, space, etc., correct?
Thanks in advance!!
ItBeMe
Color: Very dark blue
Re: Possibly to add DC 12V "cigarette lighter" socket
Post by ItBeMe »
Yes go for it the fuse panel is right there,
I had both on my bike but decided to just go with the battery tender accessory because my GPS died and charging my phone was my only other use for the accessory outlet. Yes, it can be done on a 2013 model without a lot of effort, and you can get a waterproof one as well. Just decide where you want it and how much effort you want to put into it.
