Fault code help
buddy1976
Fault code help
Post by buddy1976 »
Can anyone with a bit of knowledge or a service manual please help me translate these fault codes?
Scoot is running ok apart from intermitent solid warning light and speedometer behaving erratically or sometimes not working so i'm thinking speedo sensor/ rear loom may be at fault but looking at the light sequences i think there may be a few faults flashing up?
https://www.youtube.com/watch?v=p0jnlmD ... e=youtu.be
Honda forza 125 2019
Yellow malossi contra spring
Malossi delta clutch and bell
Malossi special kevlar belt
K and n air filter
Akrapovic exhaust
Malossi White Contra Spring
Malossi yellow clutch springs
Daytona reinforced belt
DNA Performance air filter
Removed air box flange
Removed seat hump
Ermax+25 windshield
buddy1976
Re: Fault code help
Post by buddy1976 »
buddy1976 wrote:Can anyone with a bit of knowledge or a service manual please help me translate these fault codes?
I have rest ecu now as it was 2nd hand, i'll report back if i get any further error codes.
Thanks
K and n air filter
Akrapovic exhaust
Removed seat hump
Ermax+25 windshield
aguim
Year: Forza 300
Color: red/2014
Re: Fault code help
Post by aguim »
Your video shows: codes 11,12,52. Only that year's PCX 125 shop manual can tell you what
these codes refer to.
Code 11 simply does not apply to a Forza, by example. Code 12 refers to the Injector on most Hondas. Then code 52 refers to the PCX 150's CKP, but doesn't exist on the Forza.
Anybody with the proper shop manual ? Otherwise, since the scooter works fine but shows 3
improbable codes, swap the ECU and see what that gives...
aguim
Year: Forza 300
Color: red/2014
Re: Fault code help
Post by aguim »
buddy,
A friend of mine has just provided me with a list of 'typical' Honda fail-codes, that says code 11=speed sensor, code 12=fuel injector. At first sight, these two are not related...but in fact they are! (the ECU adjusts injector opening duration to speed, among other parameters, says friend). This could point out to a defective speed sensor 'screwing' both the speedo and the injector functions...thus showing codes 11 (one long blink, one short) and 12 (one long, two shorts).
Code 52 is not on that dated list.
Re: Fault code help
Worth checking the multi-way plug is seated properly (behind the dash area).
buddy1976
Re: Fault code help
Post by buddy1976 »
Thanks for the suggestions guys,
As my ecu was 2nd hand i have reset it using the paperclip method, have just done over 10 miles and and put into diagnostics mode and their is no faults to report as yet. Hopefully it will remain faultless, i think i'll get myself a service manual sorted sometime soon now i know how to find the fault codes.
Cheers
K and n air filter
Akrapovic exhaust
Removed seat hump
Ermax+25 windshield
aguim
Year: Forza 300
Color: red/2014
Re: Fault code help
Post by aguim »
By 'reset the ECU', I understand you mean 'erasing the memory codes'?
I don't see how this could correct an erratic speedo...I'm I missing something, here!?
buddy1976
Re: Fault code help
Post by buddy1976 »
Sorry, Yes i mean erasing the memory codes. The speedo issue is not my main concern i will be fixing that on my next day off, my main concern was after i 1st tested and found 3 different fault codes, since posting this i have erased the memory codes because i since realized they may of been inherited with the ecu i had purchased second hand earlier last year. I will now monitor for fault codes using the trusty paperclip after each commute for a few weeks.
Cheers again
K and n air filter
Akrapovic exhaust
Removed seat hump
Ermax+25 windshield
Re: Fault code help
I thought the ECU just stored past error codes but did not flag them again unless they were still present. Still, progress is being made.
aguim
Year: Forza 300
Color: red/2014
Re: Fault code help
Post by aguim »
Iceman,
Stored failure codes will only show up when shorting 2 specific wires from the red DLC (data link
connector). They are kept in memory so that intermittent problems can be identified, as such
problems may not show 'now' and be otherwise very hard to track.
On my Forza, I had disconnected just about everything related to FI , turned the switch on, and
saw the whole litany of codes blinking out, one after the other. After I reconnected everything (with the switch OFF) and started it, the blinking codes stopped altogether. Then, with the jumper-plug installed, they all came back as 'stored'. I erased them following the procedure above.
(It is VERY important NEVER to connect/disconnect things with the main switch ON, says Soichiro).
