Seat closure
				Commanman1
Seat closure
I recently purchased a used 2013 PCX 150. Love it. I'm having trouble with the seat storage latch. any ideas? I am able to open the seat but it wont catch when I close it. I have messed with latch but it wont lock.
						Re: Seat closure
Push down steadily with the flat of your hand on the rear of the seat till it clicks.
It takes quite a bit of a push due to the foam rubber seal having to be compressed.
Re: Seat closure
Oh just punch it, everyone else does.
If you have 2 minutes you can adjust the latch....
Re: Seat closure
You can also just trim down the two rubber nobs that look like big buttons on the underside of the seat.
				buddy1976
Re: Seat closure
As you you says a short sharp jab in the right place should do the job, its kinda satisfying in a weird way.
									Honda forza 125 2019
Yellow malossi contra spring
Malossi delta clutch and bell
Malossi special kevlar belt
K and n air filter
Akrapovic exhaust
Malossi White Contra Spring
Malossi yellow clutch springs
Daytona reinforced belt
DNA Performance air filter
Removed air box flange
Removed seat hump
Ermax+25 windshield
K and n air filter
Akrapovic exhaust
Removed seat hump
Ermax+25 windshield
Re: Seat closure
buddy1976 wrote:As you you says a short sharp jab in the right place should do the job, its kinda satisfying in a weird way.
 I know what you mean
  I know what you mean-
				kiapolo1887
Re: Seat closure
Glad I'm not the only one that deals with the seat latch the same way (PUNCH!)
