2016 pcx 150 break mpg
Mike888
- Color: Gray pcx150
Hi, I was wondering is it normal for mpg to be around 59. The pcx currently has 20 miles exact. Is mpg higher during break in or lower. Also what is the max speed I can go during break in. Thanks in advance
- honkerman
Re: 2016 pcx 150 break mpg
Judging your mpg at only 20 miles in is not going to be accurate.
Just the same, the first tank on a scooter usually gives lower than normal mpg.
Don't panic just yet.
doletotodole
- Color: WHITE
REALLY DRUNKENS ME WORRYING ABOUT MPG AT 20 MILEAGE...
Mike888
Oh ok, what is the max speed do you guys recommend me going. Also is starting half throttle consider bad when break in and adding mor egas to increase speed.
- honkerman
There is an ongoing civil war in the motorcycling community over how best to break in a new bike. On the one side, you have those who say ride it hard, and on the other there are those who say take it easy. For myself, I go the middle road.Mike888 wrote:Oh ok, what is the max speed do you guys recommend me going. Also is starting half throttle consider bad when break in and adding mor egas to increase speed.
During the 300 mile break-in of my own PCX, I rode it to its max if I needed to, but would roll on and off the throttle at higher speeds. My PCX turned out just fine.
- easyrider
- Color: blk
Mix RPM'S- nothing steady for a long time. Keep RPM varied. Short duration run ups only. Do not idle long periods
Mike888 wrote:Hi, I was wondering is it normal for mpg to be around 59. The pcx currently has 20 miles exact. Is mpg higher during break in or lower. Also what is the max speed I can go during break in. Thanks in advance
Has anybody seen my will to live, I've mislaid it.
No, never seen it! Probably won't either
- JohnL
- Ozzie Old Fart
- Color: Dark Red
[/quote]
Has anybody seen my will to live, I've mislaid it.[/quote]
Found it, added it to my own, you can make your own arrangements now
Have you got mikes owners manual too?
