When turn on ignition switch, not all PGM-FI indicator not o
dylant66
Post by dylant66 »
Normally when turn on ignition switch, all light indicator should on few seconds, but today I only see the fuel gauge and speedometer on, the PGM-FI usually on then off, but not today, and when I started engine, nothing happen. I checked fuses, battery, engine switch, side stand, etc, nothing wrong, it just like no power get into starter and don't hear any sound. Do you have any idea? Thanks.
Re: When turn on ignition switch, not all PGM-FI indicator n
Sounds like your battery has too weak to do its job. See if you can get it jump started. If so, then time to replace the battery.
dylant66
Post by dylant66 »
I replaced the battery last couple months, I also have have the battery charger, recharge full, but nothing happen. Like I said, starter not start at all.
Year: 26 adv 160
Kill switch on?
relic
Color: red white
Post by relic »
Kill switch on?
my first thought.
dylant66
Post by dylant66 »
Yes, I did turn it on off to make sure, side stand up, and hold brakes when starting...
relic
Color: red white
Post by relic »
I see you posted that this all started when you took the case off to change your belt
kind of points to your side stand switch but you say that checks out?
I'm stumped.
relic wrote:I see you posted that this all started when you took the case off to change your belt
kind of points to your side stand switch but you say that checks out?I'm stumped.
Dylant66 ... I am not sure where the post is that Relic is referring to, that you took the case off to change the belt, but that would be something I would check into.
I can't recall where, but there is a topic somewhere on the forums regarding disabling the side stand switch. I think it was earlier this year, but may have been longer ago than that. If you can find it, it may be of help.
Welcome to our forums :P Could you be remembering one of these threads?
http://www.hondapcx.org/viewtopic.php?f ... and+switch
Or
Or
I hope your resolve lies within one of them. "Search" is your friend,....Our friend ;)
You are a rock star WN. If it can be found, you will typically find it.
