seat damper
oliver
Year: 2014 Forza
seat damper
Post by oliver »
I took my Forza to the dealer yesterday for the latest recall work and now my seat doesn't stay up when it's lifted. I know I can take it back and have them fix it but it's quite a trek and I don't want to spend another 3 hours in their waiting room.
Presumably they took the seat off to get to the fuel pump so could it be a problem with how they assembled it back together? Is this something a novice could somehow adjust?
The instructions I have for seat removal are:
REMOVAL/INSTALLATION
Open the seat.
Remove the joint [1] and the opener damper [2] from the seat [3].
Remove caps [4], nuts [5] and seat.
I know there's no picture here but it looks like the joint [1] and damper [2] just pull out. Is that correct?
Is there some kind of trick like having the seat fully up when you re-attach?
MBMyer
Re: seat damper
Post by MBMyer »
The seat damper is known to have problems, and those problems are worse when the ambient temperature is colder. I had mine changed under warranty, but the new one is still insufficient. Check out this thread and my current imperfect solution:
http://hondapcx.org/viewtopic.php?f=21&p=95217#p95217
6 other previous bikes
oliver
Year: 2014 Forza
Re: seat damper
Post by oliver »
Thanks... I've been finding a few other threads about it on here too. Perhaps it is the temperature after all and I didn't notice it before.
I wish that seat worked like a dishwasher door where it stayed at the position you left it at.
SteveP
Re: seat damper
Post by SteveP »
I removed the seat damper last year to see if I could find a way to add a spring to it to give it more holding stremgth. Couldn't, so put it back. It worked a little on warm days before removing it...hasn't worked at all since then! I think someone here claimed Honda has an improved, stronger one for replacement... but not sure. So far I haven't tried a new one...jut holding seat up with my hand. Temped to go with a stick!
Re: seat damper
Not sure it's a seat damper or even dampener :D :D o_O . Perhaps a strut or brace?
GeorgeSK
Year: 13PCX,15Forza
Color: Both Red
Re: seat damper
Post by GeorgeSK »
Call it what you will, but I have been calling it a huge annoyance. But no more! Thanks to the encouragement of Obayan in another thread on this topic, I had the "damper, opener", replaced (part 83590-K04-932) while Forza was at the dealer for the latest fuel pump recall. I was within three weeks of warranty, so there was no charge. The seat actually stays up! We shall see about colder temps (it is currently 50 F), but it feels far more secure.
As far as the OP - you might try to loosen the bolts on the hinge slightly and see if you can get the holes on the seat part of the hinge as far back as possible. There might be a couple of mm play in the bolt holes, and it may be helpful to give the "damper, opener" as much leverage as it can get.
MBMyer
Re: seat damper
Post by MBMyer »
GeorgeSK wrote:The seat actually stays up! We shall see about colder temps (it is currently 50 F), but it feels far more secure.
I had mine replaced under warranty, but it still doesn't work in cold weather. I've installed a marine hatch spring.
http://hondapcx.org/viewtopic.php?f=21& ... 900#p95900
Michael
dergav
Color: grey
Re: seat damper
Post by dergav »
MBMyer solution works a treat...problem solved.
