fuel maps
troy
- Color: red
fuel maps
HI! Does anyone out there have any fuel maps for the Honda PCX with mods they like to show??? is anyone running the Yuminashi PGM-FI CONTROLLER FOR PCX150 V1 ( can I see map 2) 0n it please???
Re: fuel maps
Mate, you need to get that thing professionally dyno tuned with correct AFR, or risk damaging your engine!
You will not get that by sharing maps from someone else even if they had the same mods with the same atmospheric conditions, as every bike is different.
Find a tuner with a braked dyno that can hook up their MoTec or Dynajet exhaust sniffer to read the AFR and give you a perfect tune for maximum power.
If you bought the USB dongle with the PGM-FI unit, dyno tuning from a laptop will be easy. Otherwise you will be limited to the 3 RPM range adjustment dials...
