Unused connector
Posted: Thu Sep 22, 2016 1:16 am
I noticed this unused connector right next to the negative battery cable but was not hooked up to the battery. Anyone know what this is for?
https://hondapcx.org/
If it was a standard OBDII port like in cars, you could connect an ELM327 or similar dongle and bluetooth that information to your smartphone for full realtime display of all information.homie wrote:LOL.. I don't think so, but I wish they would allow for user interface with full diagnostic software.
I've used that very plug with full diagnostic software on my own PCX. It was a third party diagnostic suite, but Honda has their own as well. As for the Jumper, the manual lists it as SCS device connector. See pic.homie wrote:LOL.. I don't think so, but I wish they would allow for user interface with full diagnostic software.
It is not a true standard OBDII implementatation, as ghatvus not required for bikes. However it is a full diagnostic port which can be used with a scantool.chicaboo wrote:If it was a standard OBDII port like in cars, you could connect an ELM327 or similar dongle and bluetooth that information to your smartphone for full realtime display of all information.homie wrote:LOL.. I don't think so, but I wish they would allow for user interface with full diagnostic software.
Oyabun wrote:It is not a true standard OBDII implementatation, as ghatvus not required for bikes. However it is a full diagnostic port which can be used with a scantool.chicaboo wrote:If it was a standard OBDII port like in cars, you could connect an ELM327 or similar dongle and bluetooth that information to your smartphone for full realtime display of all information.homie wrote:LOL.. I don't think so, but I wish they would allow for user interface with full diagnostic software.
The dash light signals general fault, but the mil code is blinked by the diagnostics sequence initiated by the plug. It also enables clearing the codes.iceman wrote:I thought the ECU gave the codes on the dash whether the device is plugged in or not? Some people report problems with their bikes and the dash light flashing short / long flashes. So, this port is needed for general 'mil code alerting'?
Yep, that's the one. Punch in that part number and you can get one off partzilla.homie wrote:Ah yes.... the little jumper that gives you a morse code like sequence for general diagnosis on the road. These are small, handy and very portable. I keep one on board, so where do you get one for the Honda?
A paperclip from the stationary cupboard?homie wrote:Ah yes.... the little jumper that gives you a morse code like sequence for general diagnosis on the road. These are small, handy and very portable. I keep one on board, so where do you get one for the Honda?
Excellent Honky! I will take that, yes please go find us the program and we shall see what kind of sensors are install on the Precioushonkerman wrote:Yep, that's the one. Punch in that part number and you can get one off partzilla.homie wrote:Ah yes.... the little jumper that gives you a morse code like sequence for general diagnosis on the road. These are small, handy and very portable. I keep one on board, so where do you get one for the Honda?
http://www.partzilla.com/parts/detail/h ... oCOC3w_wcB
As far as the software goes and computer cable goes, they had it at the school I attended. I don't remember who made it, but I can probably find out.
Not sure if that's just a wire, resistor or diode wrapped up in a candy shellhonkerman wrote:Yep, that's the one. Punch in that part number and you can get one off partzilla. http://www.partzilla.com/parts/detail/h ... oCOC3w_wcB
Just a wire. Lol.iceman wrote:Not sure if that's just a wire, resistor or diode wrapped up in a candy shellhonkerman wrote:Yep, that's the one. Punch in that part number and you can get one off partzilla. http://www.partzilla.com/parts/detail/h ... oCOC3w_wcB
