New eSP on 125 top speed increase over older models?
- figurehead71
Not sure how many users on here have the PCX 125 eSP engine.
So I took my new Red PCX 125 out for it's first lengthy ride to my parents house and back 110 mile round trip, partly to go and spend some time with them, partly to get the bike "bedding in".
I was surprised that with my lard ass (5' 10" 240lbs) that I was able to max out on a dual carriageway at 67mph, admittedly I had a tail wind and a 1/3rd mile straight stretch with a slight decline.
Starting to gain in confidence on it, really loving the handling, the grip in wet (few rain showers on the way back) the smooth acceleration..and for the most part the agility to keep with the flow of traffic.
Would be interested knowing what speeds others smaller/lighter are getting out of the new 125 eSP engines.
- EddieC
Re: New eSP on 125 top speed increase over older models?
where are you located? Wondering if your MPH is US or other MPH. You should put that info in your profile
67 on the speedo?
If so that's the same as the previous model.
- figurehead71
UK.....I guess I should.EddieC wrote:where are you located? Wondering if your MPH is US or other MPH. You should put that info in your profile
- figurehead71
Surely for lighter riders? My lard ass and having the underseat storage full I was surprised. If 67 was the max for the previous model then with my weight I would have expected less.gn2 wrote:67 on the speedo?
not sure if its true but the eSP engines have a slightly higher rev limit hence bit more top speed.
If shame they dont come in white as standard, only red for now
I used to see 67 easily enough and I'm taller than you and have the aerodynamic qualities of a brick outhouse.
- figurehead71
Out of the 4 different colours it came down to the choice between the white or the red, both the wife and myself liked the red and with it having an improved fuel economy as well.Cracksta wrote:not sure if its true but the eSP engines have a slightly higher rev limit hence bit more top speed.
So, if it does have a slightly higher rev and top speed I would be expecting someone smaller and lighter to be able to push 70+ out of it.
I've got a red ESP 125 and it flies along (relatively) and I'm six five and 95kgs. I started a similar post a while back and got the same response from the same person
- haildamage
check it with a GPS. as i believe to be typical, my speedo indicates about 10% faster than the actual speed as shown by a GPS navi unit which tend to be very accurate, so that would mean you are actually topping out at around 60MPH if that is also true with your speedo.
I am 174 cm and 73 kg. My top speed "so far" is 110 km/t, about 68 miles. I have an 2012 125 eSP.....figurehead71 wrote:Not sure how many users on here have the PCX 125 eSP engine.
Wow, you guys are getting 67 indicated on the non esp 125s!? I took mine out on a long stretch and decided to open it all the way up to see what it would do... and it didn't get past 55 indicated wide open for a good mile and a half. It was a bit windy (about 15-20 mph gusts) and I've only got a bit over 200 miles on it, so it may open up a bit more after it's fully broken in (?). I wasn't going to try it again as I don't like to run it that hard with so few miles... the little 125 is really working it's heart out and I need the thing to last me a loong time. I'm about 5'11 and 215 lbs.
I thought the red ones were supposed to be faster?
Alex
2011 Suzuki Burgman 650
2011 Honda PCX 125
2011 Honda PCX 125
- haildamage
you'll probably find that it runs better and faster as the engine breaks in and loosens up. please let us know. both PCX engines have more than enough power to hit 100kph or 60mph but are somehow restricted to roughly those speeds. therefore, the bike can get there quite easily even with a heavy rider.
as i said before, the speedos tend to not be completely accurate and tend to err on the high side. therefore, speeds that are reported by only using the stock speedo should not be taken as the actual speed. i had mine up to 108kph today at the limiter, but i know from running a GPS/navi that the stock speedo indicates about 10% faster than the actual speed on mine.
Yep my original model 125 gets to 67 indicated and I am comfortable behind my tall Ermax +25 screen. Speedo is supposedly 8% overreading according to other posts but since I didnt buy the PCX for speed I havent bothered checking against a GPS.
I’ve been told Honda calibrates speedos to be 8% optimistic everywhere except in the US where they are calibrated spot on.
It is pointless to compare top speeds if we are using different speedo calibrations. You fellas on the other side of the pond just THINK you’re going faster than us.
My Burgam reads about 8-10% optimistic and it was my understanding that pretty much all motorcycle/scooter speedometers do... though my PCXs speedo does seem pretty accurate.
Alex
2011 Honda PCX 125
2011 Honda PCX 125
This is exactly it.Urbanian wrote:I’ve been told Honda calibrates speedos to be 8% optimistic everywhere except in the US where they are calibrated spot on.
For a long time, I was compiling top speeds here. You'll notice that all the UK scooters top out at 66-67 indicated, 60gps, whereas the US scooters top out at 59-63 indicated, 60gps.
There is not a speed increase from the eSP model, but there is a MPG boost of 5-10%.
