Hello all,
can somebody explain how to adjust throttle free play on PCX 150 single cable ?
I have 2 cm free play in throttle..
PCX 150 Throttle cable adjustment
montliz44
- Year: 2013,2014
- Color: red+redder
Re: PCX 150 Throttle cable adjustment
Robert, just one question first: Do you mean 2mm? If so, that would be in the correct range of play. Honda says 2 to 6 mm is normal. If it is 2 cm, that's a little sloppy but it can be adjusted easily. From the right side of the scooter, look over the top of your radiator cap. You'll see a black rubber overflow hose and then just past it and a little to the front you'll see the throttle body plate and cable adjuster. You can get to it without removing any body panels if you have a small enough wrench.
Easy fix.
Johnny
Easy fix.
Johnny
- honkerman
If it helps, here is the info from the service manual.
- image.jpeg (48.74 KiB) Viewed 2404 times
